UPDATE: Read last post by me plase. I really would appriciate some input on this. Driving me nuts.
It has got to the stage where the car, just coughs it's guts up in the morning and then coughs some more, untill bang 1200 rpm.
________________________________________________________________________________
________
This is exactly what is happening to my car
"Hey just a small annoyance with my cold start. When starting the car up for the first time on the day the idle goes to like 600,700rpm kinda stumbles then just revs out kind of wakes up and then just warms up normally and yeah everything else is fine i know kind of picky but yeah just abit annoying. For the rest of the day turn the car on when cold warms up normal but if its not driven for more than a day or two then yeah does it again could be the cold but also wondering if it may be related to the tps??"
My car also seams like it only fires up 3-4 cylinders, then clears its throuat and fires up all 6.
The compresion test is ok 150 across all cylinders.
Does anyone know the anwser to this.
Post taken from
http://www.skylinesaustralia.com/forums/in...=124145&hl=
Edited by WogsRus
I used to have issues with idling even when warm.
Commuting after an hour and at the lights and it would just drop and stall...or go up to 1200.
Now have Power FC and hasn't happenned since. Dunno why.
Also, there is an ACC (or AAC) valve cleaning thread in the DIY section. That controls your idle. Doesn't look like too much work so maybe give that a go
nope car uses no Water ot oil, has no blow by or anythign of that nature. Itseams to have started to happen after I started to modify the car. I am running a Centra 20 ECU, which does not have the little idle adjustment screw on it, so i am not sure at all.
There is no wate rin the oil or vice versa. Engine compression is 150psi across teh board, and all seams ok. I wander if it sould be a leakying injector or something?
What's a: Centra 20 ECU?
Is it compatible with the s2 engine?
Has the cold start been tuned properly?
Have you tried refitting you std ecu in?
This sentance makes no sense, please clarify: "There is no wate rin the oil or vice versa"
Could also be a leaky injector, but i'll check my mods first, as it only started once you started to mod it.
Central 20 is a tuning house in Japan. Its a remaped Ecu from them
The cold start is preset. It is not tunable in Australia, as Dr DRift has not got the hardware to do so yet.
There is no water in the engine oil or vice versa. So radiator and sump are both clean, no problems there.
It did the same with a standard ecu. The ecu does not have an autolearn function, like a PFC, it's preset to a set map and that's it.
Reseting has not done anythign at all.
I have replaced the watter coolant temperature sensor already, as the old one was bugared, this one has done abut 6 months work.
The thing is, it only does it first start in the morning. If i start the car any time after that, it is ok, no probs there.
When stock, the car had no issues, it's only after i started to mod the car, that this has begun to occur.
It did the same this morning, it kicked over on 4 cylinders or so, then coughed and fired up into life
OK GUYS SO HERE IT IS AND STILL NO GOOD.
I maybe thorght a head gasket, but ie:
http://www.skylinesaustralia.com/forums/in...id=2943614&
But nope all fine.
SO what i did is this.
OK well so this morning, after running the car empty of fuel last night in the fuel rail (pump off car cranking and fired up) and the cap of the radiator to stop any pressure into the block.
THE Car still started like crap. DAM IT. i dind't get a chance to clean the AAC, but that seams to work ok, once the stumble has disapeared.
I primed the lines, waited for the pump to go off, and blupp, blup blup, cough, cough, vroom 1200rpm. ONLY WHEN COLD IN THE MORNING DAM IT.
I have almost rulled out the head gasket, as it never uses water, not a drop, no bubbles ect.
So i checked the plugs and this is what they looked like, ALL THE SAME, i also put some REDLINE FUEL CLEANER SI-1 as i have had so many good reviews about it, but have only done 50km sinse that was done, so see how it goes.
SO WHAT THE HELL IS IT.
What is the best test for vacume leaks, i have sprayed arround with carb cleaner, nothing.
What i was thinking, is getting my smoke machine, yess i have one, putting the smoke in the cooler piping, through the turbo, basicaly where the AFM is, and pressurising teh system to 15 psi with an air comressor, that way the smoke will give me an indication of any leaks.
I am loosing so much fcucking sleap over this car, i just want it to run right. COME ON.
HELP ME before i sell it.
PS. For images of sparks please read above thread.
Mate living in Tas means anything to do with an import, will cost 10 times more then a Falcodore.
It sux, hence why i do it all myself.
Also being a mech engineer (who can't spell), i figure i can do it
I don't trust any mechanics with any of my cars. Esspecially here in tas.
Nissan here are usless, stuffed up so many cars, no one goes there for servicing. Consult comes back with nothing.
Oh well any more ideas????
outside of rail, you mean remove them and get sonic cleaning?
If so, then nope, not yet, but about 15k ago they were pulled out and found to be fine. But like i said, i drained the whole system of fuel, and then let sit over night. So there was no fuel in the injectors. Then after repriming the lines, it still did it.
Stock ECU no differance, did the same.
No i have not tried and AFM as yet, it has been cleaned, but still teh original item. How does the AFM contribute to this issue only when cold, and fine all the other times?
Thanks guys keep them comming.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
