Picked this up dam cheap (well for perth anyway) had been complied but was yet to be lic and was missin heaps of bits, its an absolute pig to look at but i'm a spraypainter so in good time it will b lookin all sweet. At the mo i'm not to concerned about paint cos then i'll start stressin about leavin it anywhere or pushin it when on the track.
anyway the specs r:
89 Cefiro factory 5 spd man
RB20det
R34 turbo
GTR fuel pump
china FMIC
full 3" turbo back exzorst
M's pod filter
Tein HR's (actually A31 spec not S13)
adjustable castor rods
front and rear strut braces
pineapples set to "drift" hehe
Uras steering rack spacers
Hicas lock bar (altho upon installing this found the hicas rack was already locked in place with shims)
17" Volk copy rims
Wonder copy body kit
very dodgy japan spec respray from grey to white
JJR deep dish steering wheel
full 6 point roll cage
JJR fixed back drivers seat on Bride superlow rails
Autogauge smoked Boost, water and oil pessure gauges
fly off handbrake button
Future mods
External gate on stock manifold (gettin these cheap of a mate or i wouldnt bother yet)
Shims in my tired viscous till i can get my hands on a 2-way
have a GREX oil filter relocator, just gotta buy some lines and an oil cooler for it
5-puk clutch
GTR injectors
Remapped ecu
Adj tie rod ends
either get current coilovers rebuilt or get some new ones they r a bit bouncy in the front
and an artistic one for teh hell of it :D
https://www.sau.com.au/forums/topic/157881-mikes-89-ceffy/
went down and bought myself some 3" exhaust pipe from local exhaust place this mornin so i could make new tail pipe(s).
Unfortunatly neither of the exhaust places i went to could supply a 3" 2->1 adapter so i bought a bit extra pipe and had to f**k about for nearly 2hours cuttin, bending, welding then bendin some more to make a nice unrestrictive Y piece.
Got it all together and f**k me is it loud still has cat and a center muffler but has an awsome real deep burble to it.
pics:
https://www.sau.com.au/forums/topic/157881-mikes-89-ceffy/#findComment-2950220
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
