Originally posted by Sumo
Holden tell people to drive off as soon as they start the car with their new ones. They believe that it only consumes fuel and the motor warms up better if u just take it easy driving for a few kms.
Sumo
yeah but would you trust someone who makes a commodore?
i believe at the bare minimum a minute or so to give time for the oil to get around the engine. i usually give it 3 - 5 mins and then drive easy 'till the gearbox warms up too.
to me it doesn't seem like much if it will help at all to reduce wear.
Waz.
https://www.sau.com.au/forums/topic/15798-warming-car-up/#findComment-323356
Holden are more conserned with percieved fuel economy of their cars-they dont want you to waiste fuel idling in the driveway,and then tell everyone that Holden has crappy fuel economy.
https://www.sau.com.au/forums/topic/15798-warming-car-up/#findComment-323388
I kick it over, get settled, and proceed to tackle the carport / driveway. By then, the oil should have gotten around enough and I just take it easy until it's reached operational temps. It's useless to let your car idle for 10 minutes and then proceed to give it stick, because as RedlineGTR said, you still need to warm your gearbox and diff.
https://www.sau.com.au/forums/topic/15798-warming-car-up/#findComment-323581
well i takes my car about 4 to 5 min tops for the temp guage to get to the right spot and thats wheni take off i dont give it alot of rpm proberly no more than 3 for a few min and then i prob go ujust a little over i dont rev my car much just got it worried ill hurt the baby =)
https://www.sau.com.au/forums/topic/15798-warming-car-up/#findComment-323600
Guest Boxhead
meh i dont like to let engine warm up, i figure if im gonna stay low with rpms to let gearbox etc warm up, the engine will warm up in same time...
that b eing said, i switch on car, then usually change cd in stereo, get settled. close garage door and reverse out driveway so about 30secs give or take idle before driving, i wont boost till engine and oil temps are at appropriate levels
https://www.sau.com.au/forums/topic/15798-warming-car-up/#findComment-323631
I start mine, let it idle for a few seconds so that the oil has a chance to circulate through the engine and then put the clutch in and select 2nd, let the handbrake off (since I'm on a downhill slope) and then ease it into gear and drive off sedately (:D
I don't have the time to start a car and then sit around playing with my stereo for 5 minutes, and driving it gently warms it up faster anyway.
https://www.sau.com.au/forums/topic/15798-warming-car-up/#findComment-324331
Hey so have any of u guys got remote start at all? Hell yeah everyone needs to idle or drive slowly to let the water and oil warm up, but I would like the idea of remote starting the car knowing that I would be going out in a sec, and then jumping in the car and then taking it easy for less time before it is completely warmed up.... before BOOOSTING
https://www.sau.com.au/forums/topic/15798-warming-car-up/#findComment-324627
i start mine, let idle for about 15 sec, reverse out driveway, then take it easy (under 3000rpm) with low load (driving off boost) as much as possible, until about a good 10km of driving, then gradually drive it harder if desired :P
even audi's manual for my dads S4 twin turbo states that u should not warm it up before driving, but instead drive softly on the move until operating temps are up (they got oil temp gauge) unlike our cars which have oil press. the diff and gearbox do need to be warmed by driving not idling.
https://www.sau.com.au/forums/topic/15798-warming-car-up/#findComment-324702
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
