  • Replies 84
hey! that was my first thought! :)
wish i knew one! :) sometimes i think i have a major case of NFI!
lol dude.. you need to take a chill pill... those comments are uncalled for!
you post something random on a forum.. people are bound to comment and ask question.. you don't want it or like it, then don't do it.. simple!
Some intelligence might be nice, but I guess that's beyond mosts comprehension eh!
lol!!! ok... do you read the forums when threads like this are started?! its general knowledge that they get hammered with crap!
Standard Operating Procedure I think is the correct term Mona :)
And Liz, I have the perfect cure for N F I Syndrome, it's the same for a crook horse, an ounce of lead between the eyes. Guaranteed success every time & for sure! will never suffer from it ever again.
Aren't you just the typical women! F@#KED IN THE HEAD
That sort of attitude will really help you.
If you're going to be like that, then go find it out 'by other means', you kunt.
f**k off.
steve, the doof machine wasnt white when I saw it, it was filthy!!
more like an off,sour white
LIES! SLANDER AND LIES!!!!!! :)
yeah i hadnt washed it for a little while...
Edited by DRD-00F
f**k off.
What sort of attitude do you expect???????
I was seeking some information and everybody that had SFA intelligent to say, did this.
There are people on this thread with their name down to visit Heasman's in April? From what they have had to say here today I wonder why, because they have demonstrated they have nothing between the ears, so why would they waste their time on something so technical.
Now! as you so kindly pointed out, I have.
I now know Name and Address of the culprit, so I guess he can look forward to my visit in the near future.
Enjoy the crap you spill on here because I wont be needing you any longer. I have what I needed and all it took was a phone call.
oh yeah!!! thats what i was thinking of! thanks! :D
lol this guy probably had a run with him and beat him and now he's having a cry
lol!!! i like the way you think! :)
dude.. you sound like a keyboard warrior... why would you even attempt to find out details of this person through a forum anyway! people here are INTELLIGENT enough not give away people addresses etc to some random stranger! so guess we alll have more sense than you give us credit for!
and by the looks of things, you've obtained your information through some illegal method, otherwise you wouldn't have been so hesitant in the first place, and you certainly wouldn't have tried here first! We all know the plates of the car you're looking for, and i'm sure SAU will not hesitate to pass your login info to the police should something happen! if you have a problem with this guy/girl then go via the proper channels rather than try to be a hooligan and a hero
OH! and i'm sure invasion of privacy is a lockable offence
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
