Google searches may help further, or break out the calculator:
1.8mmhg (actuall x100 on the scale, right?) = 180mmhg
760mmhg = 14.7 psi. (700mmhg on the scale is about 14psi)
52mmhg = 1 psi
180/52 goes 3.46 times. 3.46x 1psi = 3.46psi?
Well, probably totally wrong... but i've been awake for 24 hours now, so I suggest you do that on a calculator and double-check it. ;o)
https://www.sau.com.au/forums/topic/158018-boost-question/#findComment-2933885
52mmhg = 1 psi
The calcs are near perfect.... but that sounds very strange? Sure its only 1.8?? mmhg??
https://www.sau.com.au/forums/topic/158018-boost-question/#findComment-2944399
I take it you just bought your car? You have a powerFC or something?
I'd say probably go to a workshop or tuner and get them to have a look. I agree with shortie with the AVCR reading in BAR, that sounds more correct. And if that right and you only got stock turboes you may need to tone it down a little.
You have any local mates who can have a look at your car and tell you a bit more bout it? May be a good idea
https://www.sau.com.au/forums/topic/158018-boost-question/#findComment-2944717
help...me guys huhu... nobody knows here about my car...don't even have a dynos here... i don't have a powerfc...i only have safc and avcr...how will i check if i have stock turbos??
i think my acvr reads mmhg below 1 bar??? am i right??? then 1.0 above i don't know the unit??? the avcr is really register top boost of 1.8...im not sure of the unit....
if i will adjust the acvr lower the duty cycle,ill keep the top boost below 1bar...does this mean im gonna lose power????
thanx
Edited by andy95'R33GTR
https://www.sau.com.au/forums/topic/158018-boost-question/#findComment-2945468
