I put together the schedule of the Motor Show held in Japan in 2007.
Please take advantage of this links(^-^)
Nagoya imported car show 2007(1/6,7)
http://www.importcarshow.jp/outline.html
Tokyo auto salon 2007 (1/12-14)
http://www.e-autosalon.net/tokyo/english/index.html
14th Hiroshima imported car show 2007 (1/27,28)
http://www.jaia-jp.org/e/index_e.html
2007 Gifu imported car show (2/10,11)
http://www.mark-ad.com/gifuyunyusha/show/index.html
2007 Kyoto imported car show (2/10,11)
http://kyoto-ias.jp/index.html
13th 2007Kagawa imported car show (2/10,11)
“DREAM OUTDOOR†Camper & RV show 2007 (2/10-12)
http://camp-rv.com/2007/gaiyo.html
Osaka auto messe 2007 (2/10-12)
http://www.automesse.jp/
18th 2007 Ehime imported car show 2007 (2/11,12)
http://www2.rnb.co.jp/web/yunyusya18/index.html
f*kuoka auto salon 2007 (2/16-18)
Sendai imported car show 2007(2/17,18)
2007 Mie imported car show (2/17,18)
http://www.mark-ad.com/mieyunyusha/top.html
All maker kei car & bicycle fair (2/17,18; in Miyagi)
http://www.vehicles2007.jp/index.html
Nagoya Camper &RV show 2007 (2/24,25)
http://www.jrva.com/
Nagoya auto trend 2007 (3/9-11)
http://www.n-autotrend.com/
Osaka outdoor festival (3/10,11)
http://www.tvo-event.com/07of/index.html
2007 Osaka imported car premium fair (3/10,11)
http://www.kic.gr.jp/
6th international auto after market EXPO2007 (3/16-18; in Tokyo)
http://www.iaae-jp.com/english/index.htm
Tohoku Camper &RV show 2007 (3/17,18)
16th Hokkaido motorcycle show (3/17,18)
http://www.hmg.or.jp/
The LOWRIDER Car Show Japan Tour 2007 Kick Off in Makuhari (3/18)
http://www.lowriderjapan.net/
23 th Osaka motorcycle show 2007 (3/23-25)
http://www.motorcycleshow.jp/
Camper & RV festival 2007 in Hiroshima (3/30-4/1)
34th Tokyo motorcycle show (3/30-4/1)
http://motorcycleshow.org/index.html
EBBRO Shizuoka nostalgic car festival (3/31-4/1)
http://www.nostalgic.co.jp/
Exciting Car SHOW DOWN (3/31-4/1; in Nagoya)
http://optionland.jp/showdown/
Hokkaido Camper festival (4/7,8)
Barrier-free 2007 (4/12-14; in Osaka)
http://www.itp.gr.jp/bf/eng/new.html
7th TECHNO-FRONTIER (4/18-20; in Makuhari)
http://www.jma.or.jp/TF/en/index.html
JOINTS CUSTOM BIKE SHOW 2007 (4/27; in Nagoya)
http://www.joints.jp/
Nagano nostalgic car festival (5/3,4)
http://www.nostalgic.co.jp/nagano.html
SIS Tokyo special imported car show 2007 (5/11-13)
http://www.sis-t.net/
Garage & Housing EXPO 2007 (5/11-13; in Tokyo)
http://www.g-hexpo.com/style/
BP Tokyo nostalgic car show (5/12,13)
http://www.nostalgic.co.jp/tokyo.html
Tokyo premium motorcycle show (5/12,13)
(no link)
10th Welfare 2007 (5/18-20; in Nagoya)
http://www.u-net.city.nagoya.jp/welfare/
Automotive Annual Congress 2007 (5/23-25)
http://www.jsae.or.jp/index_e.php
Sapporo auto salon (5/26,27)
Kyusyu Camper show 2007 (6/2,3)
BP Nagoya nostalgic car show 2007 (6/2,3)
http://www.nostalgic.co.jp/nagoya.html
31th Auto service show 2007 (6/15-17; in Tokyo)
http://www.jasea.org/a.s.show/
Mobile Electronics show 2007
http://www.mes-web.com/top.html
7th Auto Galley Tokyo 2007 (8/3-5)
http://www.auto-g.jp/agt/ (2006 version)
BP Osaka nostalgic car show (9/2)
http://www.nostalgic.co.jp/osaka.html
Kanazawa nostalgic car festival (9/22,23)
http://www.nostalgic.co.jp/kanazawa.html
40th Tokyo Motor Show 2007 (10/26-11/11)
http://www.tokyo-motorshow.com/eng/index.html
2007 Tokyo truck show (10/28-30)
http://www.truck-x.com/truckshow/2007ts_info.php
15th Nagoya motor show (11/22-25)
http://www.chukei-news.co.jp/motor14/ (2005 version)
5th Osaka Motor Show (November or December)
(no link)
YOKOHAMA HOT ROD Custom Show 2007 (12/2)
http://www.mooneyes.co.jp/english/index2.html
Thank you very much Ganta, this is now pinned/stickied. Better late than never... - Rezz
https://www.sau.com.au/forums/topic/158020-2007-japan-motor-show-schedule/
She's not a mate, she's a 'sheila'.
K****!! Arigato! Great post ne!
(do you mind if i post your name? (^_^)?)
I dont care what sex they are, i'll still call them mate, its my proud aussie tradition :D
wakatimuska?
wakatimuska?
this may seem like a silly question but what is wakatimuska? it's no japanese word I've ever heard. did you mean wakarimasuka maybe?
  • 11 months later...
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
