Plx-m300 Wideband Oxygen Sensor
@Duncan a meter will read continuity, so long as resistance is below a certain threshold. For example, on a headlight globe, you'll probably manage to get your MM to beep for continuity. I always go with measuring resistance. I've had some digital Multimeters beep continuity even with a 100ohm load. Now as for that wire that should be undamaged earthing out... I really really don't want to say it, as I hope it's not the case... Do you happen to have any evidence of mice/rats around?
This is a dc2r lip No modifications required. Installation is fairly easy but you have to screw the middle for it to sit where you want it https://www.ausbodyworks.com.au/products/silvia-s15-dc2r-front-bumper-lip Is the website I bought it from
Sick! This is exactly what I was looking to achieve. How'd you go about installing it? What modifications we're required?
nah the heater hoses are fine, I just use the dump pipe as a booster until the coolant warms up
You don't think he should leave it to torch the heat hoses?
