Hi guys just got my R33 dream car, high grade, factory standard and runs like it has just left the dealership, low kms...or has it? To my disguist I had full inspection done by State Roads in Sydney (where the car is from)and all was well. Car arrives on truck to my house in Adel and when I take it for a cruise all of a sudden I notice trip computer and odometer are not ticking over :D evidence of roll back or is this a common problem when transporting etc?
I'd appreciate all opinions and thoughts guys cos I spent some major cash $21k in fact and if I've been taken for a ride, Consumer Affairs will be notified!
https://www.sau.com.au/forums/topic/158033-odometer-malfunction/
Is it a fresh import?
Not too sure, dealer didn't say it was fresh stock and it got complianced as soon as I bought it.
Oh ok , Does the condition of the car match the kms? Like worn handbrake lever steering wheel etc ( i guess thats the only way to go by), Its very hard to say it could of been turned back here or in Japan, I asshume it has a std speedo.
I think most people accept that if you buy an import the kms would have likely been wound back. When I was getting my car inspected I asked the mechanic whether he thought the kms were genuine. He replied by saying that "anyone who believes imports have genuine kms still believes in Santa Claus." Not that this helps you much i guess...
Edited by ricsvtr
i got genuine log books since new :) cheering
Yea these are some fair points, well interior and engine show signs of a car around the 50,000km mark defintely. I think no matter how much of a pro detailer you are you couldn't get my car in the condition it is if in fact it had 150,000kms.
Only wear is on gear knob, everything else is spotless and I purposely bought the car in stock condition that way chances of being a drift car were reduced.
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
