hey guys now i just brought a series 1 r33 gtst from o,neill car yard in southport QLD and its a an auto and stock beside from the catback high flow and 600x300 front mount . and its nearly 30Littres of fuel every 200ks even on long trip and not giving it boost . boost is stock . just been dyno by who ever the dealership took it to then it was running so good after that but still running rich .. is this normal for S1 R33 gtst to go through 30L every 20ks on long trip. cheers, adam :D
what would be the problem to solve this..
Edited by adamR33
https://www.sau.com.au/forums/topic/158035-rich-fuel/
i had a 33 gtst auto and it use to be quite thirsty on the juice. Does it have a atmo BOV? I think it may play apart in it especially the BOV. i use to get about 300 ks to a tank which is not to good at all. Mite have to look at getting a safc to controll the fuel mixtures? feel free to correct me if im wrong? :D
Edited by 95SKY
https://www.sau.com.au/forums/topic/158035-rich-fuel/#findComment-2934045
i had a 33 gtst auto and it use to be quite thirsty on the juice. Does it have a atmo BOV? or Exhaust etc? I think they may play apart in it especially the BOV. i use to get about 300 ks to a tank which is not to good at all. Mite have to look at getting a safc to controll the fuel mixtures? feel free to correct me if im wrong? :D
hey thanks well the BOV is factory but notice it has the excact same mitshi 4g63t stock bov as i used to have a cc coupe with a 4g63t vr4 in it. 3inch stainless catback exhause. and whats a safc controle cheers.
https://www.sau.com.au/forums/topic/158035-rich-fuel/#findComment-2934079
change your plugs first, clean your injectors and then replace your 02 sensor. If still not happy then get a SAFC to lean it out a bit
all true
check voltages on 02 sensor... search you wil find...
plugs... etc
injecotr cleaner and a few tanks... general maintanence wouldnt hurt.
for me i had the same issue but once i changed my smic to fmic a great deal of problems went away for me... but admitedly do ALL the rest first then try this... another idea is check weather you really o have stock management in your car...
https://www.sau.com.au/forums/topic/158035-rich-fuel/#findComment-2937791
ok check my ecu , its all stock O2 senser is brand new as the car has only done 68,000ks but i know the o2 senser no where near that , should i close the gap to 0.8 and how much better will this safc do to the fuel saving well what would be to average be as mine is about 17L per 100ks..
https://www.sau.com.au/forums/topic/158035-rich-fuel/#findComment-2938269
yes i have the same problem. how do you clean your injectors, just with some additives.
You can have them cleaned from injector cleaner (but make sure the additive is suitable for turbo charged engines) but realy your best of getting them professionaly done.
Edited by 95SKY
https://www.sau.com.au/forums/topic/158035-rich-fuel/#findComment-2938976
The general consensus from pretty much all fuel based threads is -
Injector cleaner - Cleans injectors, cheap fix
Decent fuel - explanatory
Reset ECU - prevents the car from running on knock maps from crap fuel
Clogged cat - creates restriction, car runs crap
Vacuum leak - causes car to run crap
Spark plugs - wrong rating can cause crap economy
Oxygen sensor - if dead causes crap economy
Injector stuck open/faulty - causes excess fuel to be dumped
I might have missed a few, but just keep going down the list till it fixes the problem
https://www.sau.com.au/forums/topic/158035-rich-fuel/#findComment-2939373
ok i think i figered something can someone tell me if these are the right plugs as this is the one i had in it from the car yard its NGK..R...BCPR6ES... cheers...adam
p.s its an r33 rb25det S1
Edited by adamR33
https://www.sau.com.au/forums/topic/158035-rich-fuel/#findComment-2941344
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
