Not sure if this is the place to post this question, but...
Im looking at getting a new bodykit etc and thats all good. But the other day my mate had a big accident and wrote off his BA falcon. Major major front end damage. His model came out with 6 air bags and not one of them went off. They looked into this and found that the car had a aftermarket bodykit put on before he bought the car. And the reason the air bags didnt go off was either the sensors were moved changed or removed... Where are the air bag sensors in the R33 Skyline? And do you have to be careful when adding a bodykit? Has anyone come across anything lik this?
Thanks
https://www.sau.com.au/forums/topic/158036-bodykit-and-airbags/
  • 3 weeks later...
stange no one has replied.. However they sit infront of the raditor .. depending how your mate hit what he did also effects the air bag being deployed..
My sister wrote of her car by running up the ass of a taxi (i h8 taxis so HAHA!) now .. she was locked up and sliding with her nose down .. on a hyunadi accent the airbags are on the bottom of the radiator and she drove under the taxi .. so you can see why they didnt deploy.
Yes adding a body kit can effect air bag being deployed in a accident.. Ussually they are replaced ontop of the radiator where they are ineffective..
Thanks for the reply mate. i am looking to kit up my skyline and i obviously want the air bags to open in a crash. anything i should kno or look out for? or is it useally just fine?
Well just ask them to install them back to they are functional. Ussually they sit infront of the radiator like I said but often changed for mods such as a kit or FMIC in that case they are ussually place somewhere stupid..
If you say its a main point they will work to find a solution, otherwise id take my car to another garage!
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
