  • Replies 49
Chaser as well :D twin turbo 2.5L
hmmm wait a sec.. same engine as soarer.. are soarer's faster then r33's in stock form?
Same engine maybe, but the soarer is heavier... On power to weight it would go:
Chaser at 206kw in 1480kg-ish = 139kw/tonne
Skyline R33 at 185kw in 1360kg-ish = 136kw/tonne
Soarer at 206kw in 1560kg-ish = 132kw/tonne
Not that I'm suggesting that power to weight is the only factor that influences acceleration...
Hmmm.....Chaser for sure......
Does anyone Thought about the Tourqe from the TT motor should be significantly hight at Low reves than the R33...
Never really driven a chaser though... :D
Dunno about that - I've always thought the 1JZ twin turbo to be slightly laggy... Although that experience is from a 16 year old Supra. The late model single turbo VVTi 1JZGTE is meant to be far better down low.
chaser. if the skyline was manual it b close i think especially if you got a good launch (good tyres)...
Damn....i though a Manual R33 could keep up with it, given that the chaser is Auto, I know there good..but never though that good.
I have Owned Both a 1997 Series II R33 GTST and a 1997 Toyota JZX100 Chaser Auto.
The Auto Chasers Maul Manual and Auto skylines with up to 200 rwkw.
I had a Catback exhaust on the Chaser and a K&N Pod filter and with the auto ran a 13.2.
On the street, most of my mates 200 rwkw Skylines got dusted. They develop a shitload more torque than the RB25, even More than a Standard RB26.
Beautiful car - get a Manual one though, so so much better and they can pull 13s with no mods whatsoever.
Just to remind you - a JZX90 - Pre 96 Model with the Old 1JZ would be on Par with an Auto R33 - after basic mods though would eat a 33.
JZX100s Came with a Different Motor alltogether - Single Turbo 1JZ VVTi.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
