not quite sure wat u mean
i dont see how you would starve the car with a 040
wat mod you supporting
as long you getit installed right
pfc, , cooler, bigger turbz, stock injectors, full exhaust
yea i know i was told even if you install it right i'd need a ( surge tank?) cause ill run out of petrol soon as it gets in the reserve tank.
ps= i like ur car man :)
Edited by R33GOD
thanks man
umm yer surge tank is always a good thing make sure that when it comes to fuel you dont go cheap always go for the big bangers to much fuel is better than no fuel at all
im running a 044 with a 1.5 lt surge tank and a standard lift pump and that suppourst 300 rwkw
also make sure you get some teflon braided hose if you buy any one those big pumps or else you will ahve trouble after trouble
there is a thing as a fuel pump thats too big
if it can pump too much and if your sitting in peak hour traffic idling lots the pump will keep going and pushing the fuel around the rail system and back to the tank, which will heat up the fuel, giving you a soggy and sluggish response when you open the throttle
before i go tmy inj n ect i had standard ones and a 044 with a malpassi i was stupid n tryed to get as much power as possiable without any mods
anyways
the malpassi seem to over run the inj and pump a heap of fuel into the car but max sure they dont max out or else Bang..
but you should be right for say 240 rwkw max
everything is so complicated these days lol (only if you make it complicated)
what sort of pump is ideal for an r33 if not the 040?
thats very tru but i wat i was getting at was better to more than none at all cause you know wat a shortage of fuel does
040 is fine for most mild gts's
gtr is another goody (but usually 2nd hand, older)
its only like really big pumps that have the "too big" issue
like maybe an 044 or twin 044's etc
the best option if you are chasing just a lil more power with a good tune would b a walbro pump in tank direct replacment just make sure it aint a ebay on i got one of those a long tome ago lasted a 2 power runs
ive already bought the bosch one :spank:
I got a walbro with 3/4 tank syndrom. gonna aget it down further tonight, anyone know how? is it just the way I placed it back into the tank that it didnt drop down low enuff or somehting?
thast k i have a malpassi if you like but you would have to take it to a tuner if you have one cause they are fiddle lil pricks you should be able to make 220 with those mods already just get a sureg tank put your lift pump in
done
with my walbro back in the day i made a extension with some good hose with the filter at the end she sat right at teh bottom easy as
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
