not quite sure wat u mean
i dont see how you would starve the car with a 040
wat mod you supporting
as long you getit installed right
pfc, , cooler, bigger turbz, stock injectors, full exhaust
yea i know i was told even if you install it right i'd need a ( surge tank?) cause ill run out of petrol soon as it gets in the reserve tank.
ps= i like ur car man :)
Edited by R33GOD
thanks man
umm yer surge tank is always a good thing make sure that when it comes to fuel you dont go cheap always go for the big bangers to much fuel is better than no fuel at all
im running a 044 with a 1.5 lt surge tank and a standard lift pump and that suppourst 300 rwkw
also make sure you get some teflon braided hose if you buy any one those big pumps or else you will ahve trouble after trouble
there is a thing as a fuel pump thats too big
if it can pump too much and if your sitting in peak hour traffic idling lots the pump will keep going and pushing the fuel around the rail system and back to the tank, which will heat up the fuel, giving you a soggy and sluggish response when you open the throttle
before i go tmy inj n ect i had standard ones and a 044 with a malpassi i was stupid n tryed to get as much power as possiable without any mods
anyways
the malpassi seem to over run the inj and pump a heap of fuel into the car but max sure they dont max out or else Bang..
but you should be right for say 240 rwkw max
everything is so complicated these days lol (only if you make it complicated)
what sort of pump is ideal for an r33 if not the 040?
thats very tru but i wat i was getting at was better to more than none at all cause you know wat a shortage of fuel does
040 is fine for most mild gts's
gtr is another goody (but usually 2nd hand, older)
its only like really big pumps that have the "too big" issue
like maybe an 044 or twin 044's etc
the best option if you are chasing just a lil more power with a good tune would b a walbro pump in tank direct replacment just make sure it aint a ebay on i got one of those a long tome ago lasted a 2 power runs
ive already bought the bosch one :spank:
I got a walbro with 3/4 tank syndrom. gonna aget it down further tonight, anyone know how? is it just the way I placed it back into the tank that it didnt drop down low enuff or somehting?
thast k i have a malpassi if you like but you would have to take it to a tuner if you have one cause they are fiddle lil pricks you should be able to make 220 with those mods already just get a sureg tank put your lift pump in
done
with my walbro back in the day i made a extension with some good hose with the filter at the end she sat right at teh bottom easy as
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
