why no forced induction over its life?
Even though I’m way bored of it, and it owes me a fortune, if it were not to sell, which we all know it more then likely wont, I’ll throw a Vortech onto it.
I can charge it for around $5k, and @ 15psi it’s a 450hp+ car. The auto’s been built, so that won’t be braking anytime soon.
Then again, the parts to make a 1uzfe a manual these days aren’t all that expensive anymore.
All pipe dream talk really, at the end of the day I want another turbo performance car anyway.
to make it a conversion would be not too hard bullet cars sell a setup for the forced induceted 1uzfe and can even look at fitting for you
Heavy duty conversion kit (Bullet SS) $1790.00
super charger kits :
http://www.bulletcars.com/products-services/superchargers/
Thanks Mushy, someone I know has already had a chat to them, and they built “LEX S” a few years back. Bang for buck, I'm not happy with the power their setups make, although it is still an option if I can huggle them pn price/
Not really after a “blower” set up on top of the motor though, I prefer the vortech/pro-charger supercharger set up's
If anyone has Vortech hook ups yall know were to find me
LOL you started out wanting to sell the car now your after parts for it...
Only with you nismo boy can this happen....
instead of selling it to cut your losses your planing to through more money at it... i say go for it!!!
Your car has now been resprayed has it not? I'm sure I drove past it on Caloundra Rd on Monday (parked outside bike shop)... I thought it looked in pretty good shape when I glimpsed it...
I think it was a dark blue or greeny colour - can't be too sure tho, as I was just coming off the roundabout (just before the bike shop) at speed... :)
It definitely had plates similar to LXUSS though, and had some decent sized chromies - that's why I thought it was you.
  • 4 weeks later...
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
