hi guys
had this rattle for a while now but now its really getting on my nerves
when in low revs and in any gear, there is a real "fuzzy/buzzy" type of rattle on the passanger front seat side, sounds like its coming from infront of the glove box. At first i thought it was the pod rattleing against the guard but then i padded the pod up and it still happened so i eliminated that out of the factor.
the sound only happens when driving in low revs in any gear and once u pick up some revs, the sound dissapears.
i thought maybe a gasket? sounds like its coming from somewhere around the turbo
has anyone heard of this as a common problem or have any suggestions on what it could be
cheers
https://www.sau.com.au/forums/topic/158082-r33-series-1-engine-rattlesound/
do u feel it through your pedal? mine vibrates/makes an aweful sound from 2000 to 2500 rpm in 2nd, 3rd and 4th
ive been told its just the clutch out of balance at that sort of rpms so not to worry about it
My car has that same rattle or whatever it is. When it first reared its ugly head i got nervous, but it still does it 3 months on and has been on the dyno for a few hours where it made good power and the tuner didnt comment on it at all....So it cant be that bad i reckon, if it gets annoying just turn the stereo up lol....
maybe its the head shield around the turbo. might have a screw loose and be tapping metal on metal (sorta vibrates on it at low rev). just a thought.. make sure all screws and clamps n stuff are all tightned around that area. if they are, then it probably an iternal thing
was just concerned cause it comes from the same area as where the turbo is located. It sounds like a vibration like something is vibrating against something else.
it wierd cause it goes away after about 1.5-2k revs.
Strange
Yeah I have exactly the same thing, But I'm sure my comes from the gearbox. As I removed the rubber surrounding from the gear stick and it was crystal clear it came from the gearbox. I notice the sound only happens if my motor is laboring or just off it.
mine does the exact same thing. at low revs. i have a twin plate clutch though. theyre tradtionally very noisy things. and its the plates and the disc that sits in the middle thats moving and virbating and making the noise. nothing to be worried about IMO
Make sure the noise isn't coming from the front of your engine....
How many K's has your car done....
Sounds like you may need to replace your cam belt, cam bearings, and seals.....
But yeah, check the black case on front of engine at dizzy
I have the same problem... only loud when engine is cold and sounds like its coming from front of engine (not in the engine) near belt... at low revs aswell.
sounds like my problem though i wouldnt have a clue...
check the black case on front of engine?
Could you please elaborate? what to look for when im checkin the black case?
Edited by bluey33
done like 110k
its not coming from the front of the engine. it sounds like the sound is coming from infront of the glove box ,engine pay side (not inside the car :happy:) thats why i suspected my POD was rattling against my guard...but it wasnt that
the sound comes and goes fairly quick its only when the car struggles on low revs
dunno what the hell it is, and its not like i can pop the hood and look in when it makes the noise cause it only happens when moving, does happen on idle or when reving the car in N.
  • 1 month later...
Hey Peeps,
I got a rattle coming from the cam belt cover, a new belt was fitted 2 months ago, is only there when the engine is cold, once she has warmed up it goes,
any ideas what this could be??
(its a 1996 R33 S2 GTS-T)
it is booked in for a service in 2 weeks, (car is under complete warrenty untill september for all parts)
Cheers
Dazzler
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
