Hi guys I have a very clean immaculate series 2 r33 skyline for sale.
I am the second owner after my mate. Imported in 2002 and we've both only put 40000kms on the clock Therefore 80000kms at the moment.
It is only a weekend car and always garaged. Just completed a major service although it didnt come too 100000kms as yet.
New Timing Belt (Jap Brand) - got reciept
New brake bendix brake pads - got reciept
New Water Pump - got reciept
Oil change using Mobil Synthetic 2
6 x Iridium Sparkies
New Coolant
Fuel Filter
Oil Filter
Job all done @ Lam Auto Cabramatta
New XFORCE Stainless Steel turbo back exhaust system with 5 year warranty. Recently put in 2 months ago @ FUSSY'S MOTOR PERFORMANCE (SKYLINE SPECIALISTS). - Got reciept.
400R Front Bar and 400r rear pods.
Vielside Side Skirts recently re fibreglassed
5spd Manual
18'' BSA Chrome 5 Spoke Rims
GTR Wing
HKS SSQV BOV
Turbo Smart Stage 2 Boost Controller
The car has never been thrashed, beucase it is stock as a rock! No Front Mount. Never been boosted.
My mate drove like a a grandma.. and so did i.. well sometimes hahaha but i dont thrash it..
pm me for more details..
https://www.sau.com.au/forums/topic/158083-for-sale-1997-series-2-r33-skyline/
What did you install a boost controller for then?
so i was brand new when i came over here???
and is it free?? cos i cant seem to find a price but my eyes maybe a bit tired...
but i am interested if the price is right...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
