  • Replies 211
Interested parties:
akira (Deposit 18/5/03)
Prank (Deposit)
Roy
Roy's mate
Bonkers
Nissaner (Deposit 15/5/03)
Nissaner Mate (Deposit)
Shunted (Deposit 16/5/03)
Carlo (Awaiting deposit now)
Fatz (For BBQ and Heli's on the grass)
Majanal (90% now... just gotta get turbo checked)
Zane
Oz (90%)
Now we have 11/12 that are very interested some have already paid deposits... now I need deposits from the rest of you people, I WILL be ringing Dave tomorrow to give our final numbers and all those that haven't got deposits done by then WILL miss out as I know that the day is full.
Setup for this day will be 4 groups.
Group A (Fastest/Experienced Drivers)
Group B (Those that have been before but still want a bit more practice)
Group C (The Newbies and the slower cars such as excels and stuff)
Group D has been booked by a group booking.
I had thought that we would put our people as follows.
Group A, Roy, Bonkers, Zane, Oz and Majanal
Group B, Akira, Roys Mate, Nissaners mate and Shunted.
And let Prank, Carlo and Nissaner make up there own mind in which group they would like to be part of.
I believe that Duncan might be around to help out with a few tips to help people drive a bit slower and to try and convince them that cheater tyres is the way to go!
Cheers,
Dan.
just paid $50 for my friend...
Thanks for that Jon - you are a true Gentleman :)
Dan, you forgot Group F - reserved for the Fatz/B-Man 8 sec corolla project - and that's on the gravel track around the outside of EC - I think 1:55's are on the cards. :)
Oh, well one day I'll be able to run my car are EC - Looks like Pete & I are on BBQ & Beer duty (Oh, no alcohol at EC, I remember.......) :)
my friend was running in group b last year with his s15... so should be able to do group b with his type r without problem :) (i'll let him know anyway coz seeing as he came 5th overall in honda wakefield track day he might like to run in group a... ) i've always run in group c (twice actually.. only been to 2 ec track days..) but might try b this time... :)
John,
I was thinking that Prank, Carlo and yourself could decide if you want to run in A or B, C will be pretty slow this time due to D being book for a private group. You Guys will be WAY to fast for group C.
I think under 2 min for Group A, under 2.10 for group B is about right. If you don't know, or haven't been out there before, take group C with fatz, you can always move up later.
*** it the pimp wagon is in
anyone for sub 2 minutes in a stock auto r31
hahahahahahahahaha
i have to warn you the 31 pulls the best smoke shows in the world
and im going for the most 360degree spins down the grass thiis time
im all moist thining about it
pete
Ben, I reckon you should take your car around the creek - would be great fun for ya ! I'm sure Duncan, Fatz, and Dan etc would help out of you needed any ! Do it man !
Brendan
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
