Hi,
I have a friend that just bought a very tidy R33 GTR from Japan and it's on its way here. He wants to make big power (hoping for 3xx rwkw). It's pretty obvious it's gonna need a big exhaust from the turbo's back, boost controller etc. etc. but I'm more after recommendations on which garrett turbo's to get and whether or not aftermarket cams are necessary. I am very familiar with Silvia's etc and just want to know what GTR-specific things it needs.
Thanks,
Brad
theres quite a few threads on replacement twins for the gtr
check out the rb26 turbo upgrade thread stickied at the top
you are looking for
twin hks-gtss
twin garrett 2860s
twin hks 2530s
you could search for the info, but ill make it easy for you...
ECU , power FC is popular and cheap but theres heaps of others...
you will also need injectors, 700cc sards are easy, fuel pump 044 seems the go... stock fuel system is only good for ~250awkw safe...
you will also need air flow meters X2 to handle the increased flow. z32 or simlar, nismo would be my choice
and if it were me, id go the garrett GT2860r -5 turbos...
cams and cam gears, shoud see you to ~340awkw, without them, youd have to run high PSI boost to get there... ie. less safe...
Edited by groper
Checkout this thread mate
http://www.skylinesaustralia.com/forums/in...showtopic=66556
It has a link that every GTR owner wanting to upgrade turbos should read :laugh:
And then lots of other small informative links
Saves you even having to search
cheers
There is no consensus. Everyone has their own suggestions and ideas.
Just like how you thought the gtst limit is 280 rwkw. Some say it's more like 250-260. Others have put it to over 350 rwkw.
I don't see why a set of highflow turbos wouldn't make it over 300 rwkw. Gtrgeoff has a slide set, and put out over 310 rwkw on only 14 psi. on 18-19 psi, there's a lot more puff to go yet
People keep posting about poncams (etc) being a straight dropin etc Is swapping cams on a 100 000 km motor (or a fresh import u know nothing about) really a sane move without new springs collets etc etc etc which is more often than not a head off move so you would be mad not to clean up ports for better flow while its off. and if your going to go that far it isnt alot more work to check out rings bearings etc then u might as well balance while its apart.
Better to just do the full rebuild from the start!
Or just chuck on turbos and put aside cash for rebuild when the inevitable occurs!
trying to justify similar things myself at the moment cant u tell :laugh:
Edited by noone
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
