hey all
a few months after i had my tune done i started getting boost cut on high boost ( 19psi). it seems to spike quickly and cut out.
ive tried messing around with the profec by reducing gain raising the warning etc etc but its still causing a problem, the limit says max boost its hit is 1.53 bar. On low boost (around 12psi) it runs 100%
another note, tial runs a 0.9 spring.
any ideas.
https://www.sau.com.au/forums/topic/158151-boost-cut-with-profec-b-2/
the solenoid has to work pretty hard
to maintain the level between 0.9 and 1.53 bar
try and upgrade the spring, would give better control
i dont want to go to that trouble if i dont have to and the ebc shouldnt be hitting 1.5+, 19psi is only about 1.3 i think
he is running tial 38mm external gate on a TD06.
from our msn conversation, as soon as it relies on the EBC, it will over boost
Are you specifically stating that the profec B 2 is a spiking machine, or making a general across the board statement re boost controllers being unable to bring boost on without spiking when the boost is set higher than the spring rate?
neither
just trying to figure out why it's over boosting to about 1.5bar and hitting a boost cut when initially it was tuned at 1.3bar and was working fine for a few months.
the only thing I can suggest is to get it on a dyno and have another crack at tuning it. they can be hard to set up on the street just due to roads available, and speed limits etc. i had a little trouble getting mine perfect. 10 mins on the dyno and it was sorted.
its booked in for monday..
if its a problem with the tune i know the tuner will sort it out no charge but if its a ebc problem ill be up for the bill..
i tried upping the warning see if it was causing a problem but it did nothing.. seems like a typical spiking problem.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
