btw will anyone be in Hornsby early??? Seeing as I finish work at 4.... I can have lots of drinks to compensate that I will have to stop earlier as I am driving home......
Planning on going and having a few at possibly the blue gum or even directly to Hornsby Rsl.....
btw Tinks - did you read earlier post? Do you guys wanna train it and il drop u guys home?
  Sl!m said:
I'm to much of a "have-to-work-friday-nightsssssssssssssssssss"
GURLY GURL! sit down to pee kinda gurly gurl.....
oh and msnismo - we'll be taking the panda down so we can give you a lift home and you can leave your car at work or get a train to work if you want or we can pick up steve??? we'll talk tonight.....
:P sif catch a train to work :P will make Steve drive me in the morning :kiss:
  evil_weevil said:
sam, will give directions when sober....BUT, happy birthday to me!!!
LOL - pished again Chirs?! :)
...its ya birfday, we're gonna party like its ya birfday, we're gonna sip bicardi like its ya birfday, and you know we don't give a f**k coz its ya birfday...
  Tinks said:
LOL - pished again Chirs?! :D
Thats GOLD tinks :D
Better sing that for me
To everyone who was there tonight - big cheers for helping me celebrate!
Was a top night!
Coasties - you guys rock! and thanks for making the trip down yet again! the flaming lambo was...well...an effort !! :(
I left around....cant even remember what time! but everyone else went to old pub :) How was that???
Right now - I feel a bit crook, I think i'll crack a drink open, hair of the dog yet again!
now to back up for my 3rd night in a row ;)
Was a top night!
Coasties - you guys rock! and thanks for making the trip down yet again! the flaming lambo was...well...an effort !! :P
I left around....cant even remember what time! but everyone else went to old pub :laugh: How was that???
now to back up for my 3rd night in a row :)
awesome night guys - had a great time!
Chris - YOU ROCK!!! and as for the flaming lambo... I wasn't sure you'd actually skull it like you did or that it would stay down - I will never call you soft again!!! You know how to party!
Hope you had a great b'day sweet pea! :)
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
