Onyx.... What badge type did you have??? Do you have a R33 ??? I know that the series1 R33's have two different rear boot badges/locks, there is a silver and black badge found on the 92/93's and then it changes to the Pewter ( Dull metal ) look on the later 94/95 models.
When my R33 was badged at the back I looked around and found just about the only pewter styled badge in Perth at a wrecker.
Basically if yours is an R33, if you have a silver and black style badge you should find one at a local wrecker dead easy, if its the pewter type then you will have a hard time finding one but its still worth looking around. If you aint got a R33 try the local Jap wreckers anyways becauseyou never know :(
I bought mine for about $80 from memory then with a bit of fiddling took the badge portion from the lock and transferred it to my old lock ( If you have a look at the back you can understand the badge is just clipped in to the lock which can be removed )
If you have troubles finding one send me a PM to remind me and I will dig up the details of where I sourced mine from :D
Well that was supposed to be a quick response but I appear to have dribbled on so I will leave it as that.... let us know how you go :P
https://www.sau.com.au/forums/topic/15816-boot-badgelatch/#findComment-329052
The only thing I can think of is that it must be younger kids that take them for souvinears or to impress there friends.... Once they have pulled the badge of the back it actually breaks it. Basically once they have been pulled off you can't use them as a badge/ lock cover anymore.....
https://www.sau.com.au/forums/topic/15816-boot-badgelatch/#findComment-330819
