Hi All
I have decided to put my car up for sale. I'm looking for around $20,000 for it
Most details are below, though I'm sure to have forgotten bits and pieces.
1993 R32 GTS4 with RB26
Resprayed in hot house green
Debadged
Trust front bar (also comes also with R32 GTR front bar in white)
17” Advanti Stalker rims with 255/45/17 tyres all round
R32 GTR engine
Tomei metal head gasket
Tomei metal exhaust/intake gaskets
N1 oil pump
N1 water pump
700cc Sard injectors
PowerFC
High mounted plain bearing GT35R (from GCG turbos)
Tial External wastegate
Custom exhaust manifold with externally venting screamer pipe
Custom exhaust and intercooler piping
2 x RB20 AFMs
Bosch 044 Fuel pump
Brake Stopper
Nismo twin plate clutch
R32 GTR gearbox
Front drive shafts have been reconditioned
Using GTS4 diffs front and rear (better ratios)
Car has 170,000km on clock but new engine installed in Feb' of this year
Roughly 7,000km done since new engine installed
Just been serviced
Conversion work done @ Supertek Automotives in Perth
Car was tuned at Hyperdrive in Malaga – made 410rwhp @ 18psi
Ran 11.9 @ 118mph
Have dyno chart + drag slip
$20,000 ono
If interested please call James on 0402 14 14 38
or email me at [email protected]
Genuine buyers only please
https://www.sau.com.au/forums/topic/158161-r32-gts4-w-rb26-conversion/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
