R32 gtst timing belt/ water pump
steve_R32
 Share
  • Replies 41
Probably a little bit off topic, but it reminded me of the time i had to remove the harmonic balancer on my old Commodore V8, and no matter what i tried (Body weight leaning on the breaker bar, hitting it with a hammer, borrowing a compressor and rattle gun) the damned bolt wouldn't come off!!!
Even after many of my friends having countless frustrating hours trying to get this crank bolt off, one of my friends after staring at the car for quite some time, came up with the idea of getting the breaker bar, putting a piece of pipe onto it's handle to make it longer and give it more leverage and placing it underneath the chassis rail, whilst i turned the key on the starter motor, and voila!!! one crank bolt loosened by the torque of the engine's own starter motor!
keep this nifty trick in mind kids, it could have saved me many hours of grief!
  • 2 years later...
belt 1302820P25 - $82.25
water pump 2101070T25 - $97.06
Can anyone confirm these are the right parts for the RB20?
When I called the Nissan dealer, they said that is the right parts, but when 2 workshops (not just one) called them, they were both told they needed a different water pump, which is worth $386?! HUGE difference. Mechanic said that he knows the RB30 and RB25 are different (the bolt hole issue others have mentioned) but he isn't sure about RB20.
Thanks
Chris
the belt part number is the right one although mine had a diff part number on it for the one i got but it only cost $88
water pump i was also quoted $383 through nissan which i thought was crazy they must have quoted an rb26 pump or something
i done this change over last friday/sat aswell as turbo change all was reletivaly easy if you have the tools to do it
we used a steering wheel, pulley puller to get the harmonic balancer off
to undo the crank bolt put it in 5th gear and have someone stand on the brakes so the car wont move and have someone use a tention wrench to breaker bar to undo it mine came off fairly easy
total cost was $88 + carton of beer :P
Searched, and not found any concrete answers......
Can some one please tell me a definate part number (genuine, and/or non- genuine) for the R32 gts-t's RB20DET timing belt, and the water pump.
I want to be sure, so I dont have to pull it apart before I buy parts..
I have heard that the water pump is the same as the RB30 locally offered motor, but then I have heard that a bolt hole doesnt line up properly..
Where can I get a timing belt from, if not only the nissan dealer.. (I'm in Adelaide, southern suburbs) Tried motortraders, repco, sprint auto..no such luck..
Surely some of you R32 gtst owners have done the belt change yourselves? Or does everyone pay someone else to do it?
Any help is appreciated!
Steve
You don't need part numbers. Just write down your VIN number and walk into your local nissan dealer. They will give you the correct part for your vehicle. The RB25 belt should be the same as the RB20 belt but genuine is the best way to go for quality on this item. The VL water pump WILL fit your vehicle.
This is the reason I have brought this topic back. The problem is the Nissan dealer told me a $120 pump is the go, but told the 2 shops I rang that $380ish pump is the go. They are obviously different pumps. Seems the Nissan dealer isn't too sure.
I will try the Rb30 pump and see what happens
Go either the cheaper RB30 pump or the GTR N1 pump that has the anti-cavitation plate that increases flow and prevents cavitation at high rpm.
Thats the only difference between the pumps. From memory the R33 series 2 pumps are slightly different being one bolt hole is slightly aligned different. If thats the case then grab a repco Rb30e pump as they have provision for this.
  • 3 weeks later...
sorry to dig this up.. but what part no. do u use for the idler and tensioner bearings/pulley?
is it the same as the rb25? coz i seen ppl getting them from bearing places for cheap.
Matt
reason i asked coz i was hoping to buy all the parts need to do a timing belt, water pump, idler and tensioner and timing case seals in one visit to the garage.
no idea what numbers they are?
I can tell you that when I got mine done, mechanic used
- RB30 water pump
- Cam Belt - Whatever Nissan reccomended (it was genuine)
The seals I left up to the mechanic to chase...same with bearings. The bearings were not in stock at CBC, he ended up having to get to sydney (live in newcastle) to find someone that stocked them.
I plan to post up the part numbers, just I am never on the net at home...which is where the receipt is.
The RB30 water pump has the same bolt pattern and will bolt up. (Its the RB25 that has a different bolt and won't bolt up)
But does it have the same impeller?
If its different you may get cavatation at high rpm on RB20.
The RB30 revs to 6400rpm where as the RB20 revs to 8000rpm.
Just a thought, that the impeller may be different, haven't actually inspected a 20DET pump alongside the RB30 so i can't say.
The Repco RB30 pump has provision for the RB25 S2 boltup.
With regards to cavitation.. I wouldn't worry. If you are reving to 8000rpm or anywhere over 6000-6500rpm you will be getting caviation with the stock pump anyway.
For track work where high rpm 6000-6500rpm+ is used definitely look at the rb26 N1 water pump.
A prime example is Roy's engine temp differences with those few more rev's.
I've seen my RB20 pump next to the rb30 pump. No differences, same design, same fin angle etc.
eXc if u can post numbers .. that'll be handy.. when ever ur able to thats fine. as long as its before the end of the july lol.
thanks for the info.
Matt
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
