have a set of 4 tyres and rims for sale of a r32 gtst
asking $550.00 for the lot
rims are as follows
16x6 1/2 inch 5 spokes
tyres
bridgestone gridd II
16x225x50 tyres
have about 50% tread as they where when i bought the car!!!
will get some pics for you soon
https://www.sau.com.au/forums/topic/15825-stock-wheels-and-rims/
Hey dude
ill give you $400 cash asap right now if you relly want to get rid of them.
Where are you located. Im in melbourne.
Keep in touch,
Adam
P.S. Do you have any pics. Its just that I want to make sure they are not scuffed or wonky. Have they been damaged at all ?
BTW what colour are they.
If you have pics post or email me at [email protected]
Thanks Cya
Adam
