Standard Gtr 34 Injector Size
I hope you mean engine oil change haha
By soviet_merlin · Posted
Huh, you are driving a Subaru now? Or maybe it is you who is driving up RB prices... -
Really good point about checking fuses - a test light is not reliable because you might get the voltage from the wrong side of the fuse (my guess is some diode has failed somewhere). You need to check both test tabs of the fuse for continuity. With the fuel pressure mis match, I wouldn't touch it. The car was tuned with the incorrect setting so changing it is more likely to cause a problem (lean out in this case). If/when the car is next tuned get it fixed then. Thanks for the update, it is always good to add to the knowledge base
No, none of our classes allow E85, and yes I check it regularly (every engine change) and there has been no deterioration, just a bit of discolouration
