You guys can all laugh, but there IS a definite relationship.
Basically 6cc per minute per flywheel horsepower is a very close approximation of fuel flow at optimum air fuel ratio.
As you have six cylinders, and six injectors, that means max flywheel horsepower = Injector flow at 100 percent duty cycle.
So basically 550cc injectors would equal 550 flywheel horsepower absolutely flat out at full maximum duty cycle. But that is not real smart. You might want to limit it to 80% duty cycle maybe ? Which would be only 440 flywheel Hp.
But then there are drive train losses, typically only 85% of flywheel power makes it to the rear, so that comes to 374 Hp. Converted to Kw that is 275 RWKw.
Depending on the injectors you run, and assuming the fuel pump is up to the job you CAN figure out a reasonable RWKw versus injector size.
So absolutely balls to the wall with no margin might be injector size in cc x 0.85 x 0.746 = RWKw
Something safer and more reasonable might be injector size in cc x 0.8 x 0.85 x 0.746 = RWKw
Just curious as to what the 0.746 represents, that you have used in your calculations.
  • Replies 45
Posted Images
Just spoke to my tuner and he said there were no issues with the fuel pressure, it was 58psi when it was tuned.
Took the car on a longer trip and it does 11L/100km highway driving and 15L/100km for longish city driving.
The 270rwkw has been confirmed on two different dynos and I have reasonable knock figures (highest I have seen is 40 when really pushing it in 3rd).
Anymore comments?
511rwhp on stock injectors.
it's all about the batch fire....
Sorry, batch fire makes no difference, when duty cycle is 100%, its still 100% if you fire it twice. There is only ways to make more power after you reach the limit of the stock fuel system, raise the pressure, which pushes more fuel through, change the injectors for bigger ones, or get additional fuel elsewhere ie water methanol or auxillery injector.
All the guys making significantly more power than the norm, i dare you to fit the fuel rail and injctors from a stock car and do a power run, the only way to be sure that you injectors are stock is to flow them agaainst known stockers.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
