  the big JC said:
you all should be ashamed of your selves to drive someone who has helped so many people to this piont.
i will definantly keep in touch
and Sl!m and rukus you can both suck my JOHN!!
Cut out the frivolity JC, these clowns aren't worth it, they will never learn.
Go look at some profiles, this Slim dick has been a member about 2 years and has made OVER 47 THOUSAND POSTS.
Faaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaarrrrrr out, he probably has a keyboard up his ass!
Speaks loads for it's mentality and it has the audacity to challenge you.
He's the joke, just ignore it and it might go away.
Hi ghostrider thanks for your PM, i read it twice to make sure i understand you
  Quote
  Quote
  Quote
Your a f**kin MODERATOR for f**ks sake, you should know better, but obviously your just another f**kin woman ....................... f**kED IN THE HEAD and a DICKhead at that.
It's dead shits like you that get to be moderators that f**k forums.
Maybe I should have a word to Christian and have your status reviewed.
Would you be happy then .................. DICK head
you sir, need to calm down
And you need to get your act together because I have reported you to Christian, but as usual, he doesn't give a f**k about this forum.
Your a moderator??????
You should know better???????
no wait, tell me again pls
AS I SAID BEFORE ........................ The cap fits wear it
f**k may as well go to boostcrusing
but neways... lol @ threads like this
IM NOT CRYING, IM NOT WHINGING, BUT IM GONNA START A THREAD TO TELL THE WHOLE WORLD HOW IM LEAVING AN INTERNET FORUM
la di da....
its the internet, if everyone got worked up over things said on the internet, the suicide statistics would be through the roof
that thread was a good laugh.
this comment in particular.
  "N1 R33 GTR" said:
...remember that this is a forum and we will not tolerate your stupid remarks.
LOL! half the comments toward his topic were 'stupid'
i agree his comments were stupid, but it was obvious he was getting arked up. and everyone kept persisting.
he didn't have to say what he wanted details for, all he was really after was a number, not necessarily a address. for all you knew at the time maybe he just wanted to comment the guys car. however he did say the wrong thing.
i don't think this should affect you leaving the forums.
it will blow over, as always with people, you'll get along with some and not with others.
EDIT: this was typed before i had read the last post by strich9.
there wasn't much point to abuse him.
its ok.. wipe the tears from your eyes.. and log off..
If you are so sick of this place why did you have to let everyone know you are going??
and also, when people usually post these little emo threads saying "everyones so mean to me I quit the internet forever" they dont keep comming back to see what people are saying.
if you hate us all soo much.. then leave.. and stop comming back.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
