the rear of the subzero plenum does not have the plugs (purple and brown ones) the standard plenum does, does this matter.
ecu i will be using is wolf 3d v4
also it seems that theres a lot less hoses on the subzero plenum, does anything need to be blocked off before use?
It has been a few years since I installed one. From memory we used a vacumm block, 1 connection to the plenum and 5 to the various components (boost gauge, MAP sensor, carbon cannister, boost control solenoid and BOV). The idle isn't controlled by the ACC valve, the Ford throttle body had an adjustable stop for idle rpm adjustment.
:w00t: cheers :O
yep im going for 9s.... NOT! haha
greedy plenum over-rated, i like supporting quality aussie parts 'where possible'
im using the ford xf throttle- so your saying those 2 plugs (brown and purple) on the back of the standard plenum will not be used??
I've disconnected mine as well, using XF TB and PowerFC, idles fines :P here is a pic http://www.teamloose.com/pavel/R32/IMG035.jpg
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
