Hi all,
I've been a forum member for a year or two, but have only been lurking until now. Apologies if this is in the wrong area.
I'm thinking about building an R32 GTS for rallying. You're probably wondering why N/A. Basically beacuse I can build it lighter and it doesn't need huge amounts of grunt. A GTR is out of the question because the minimum weight is way too high (1590kg)
Now for a heap of questions....
How light can you reasonably expect to build an R32? We're allowed to strip interior, remove sound deadening etc, but it would have a comprehensive cage and seam welding, plus a few other strengthening things done. The minimum weight for the capacity is 1030kg, but I'd be happy if I could get it under 1200kg. If I can't get it under 1200, I'd consider building a GTS-T instead.
What will an RB25DE safely rev to?
I've been told that RB25DEs have a cast crank. Are the RB25DET or RB26DETT cranks steel? If so, will one of them slot in, and does the RB26DETT have the same stroke?
Will GTR throttle bodies/manifold bolt on to an RB25DE head? If so, what throat and port diameters are they?
What should I reasonably expect to pay for an R32 GTS landed in aus, for rally only?
If anyone has a GTS rolling shell that they want to get rid of, I'd like to hear from you.
Also, a couple of years back, I met a bloke from the Blue Mountains that was running a dark silver GTS-T with GLT sponsorship (at a state motorkhana @ Nirimba). If he could make himself known to me, I'd be really grateful.
Thanks.
https://www.sau.com.au/forums/topic/158386-r32-gts-questions/
Dude, I am doing exactly this over in NZ.
I've got an R32 GTS Coupe that I'm building to rally.
Have a look here
http://www.skylinesdownunder.com/forums/sh...ead.php?t=52581
As far as weight goes mine was down to 1160kg, stripped out with the facory front seats in and about 50ltrs of fuel on board. My main worry about using a Skyline on gravel id the poor weight split between front and rear. I think an SR20 would help this a bit, but I love the sound of an RB @8000rpm too much!
The car now has a full cage in it and just a single race seat, so I must get around to weighing it again.
I haven't seam welded mine, but I have had the cage stiched into the pillars etc and will be building suspension braces too.
I don't know about an RB25, but a mate has an RB20DE-t thats revs happily to 8,500rpm with a stock bottom end. My car just has an RB20DE and it's happy to rev the same.
Hope some of this helps.
Cheers
Shane
Edited by screamin'
I'm guessing you'll come out at around the same weight after the cage
Yeah our production car GTR weights a little over factory now it has the cage in. But the rally rules are a whole different world.
Given you are looking for light, n/a and rwd, why not look into a S13 silvia na, they are dirt cheap and should be easy to get parts for. Also plenty of people race teh sr20 so there is lots of aftermarket/race stuff to choose from
Problem is that (IMO) the S13s are butt ugly.
Screamin - Any idea what the weight split is? Have you done corner weights?
I haven't managed to find the weight split info anywhere (not that I've looked too hard).
I'm assuming that the RB20 wouldn't be that much lighter than the RB25???
There's a lot more to consider when you are into motorsport, as to which looks good or not. Personally looks would be the least of my priorities. The main things to consider is balance / suspension and ease to work on these components.
No need to tell me that. I've been competing for 21 years and have picked up a few state and national class titles along the way. :)
If I'm going to spend that much time with it, I at least need to be able to look at it in the morning.
Having grown up with Renaults, most Jap stuff is easy to work on and (relatively) well balanced. Rather than go out and buy one, then find out it's all wrong, I'm trying to work out what the starting point is and what I can do to "fix" it's shortfalls. If it's too much of a hassle, I'll probably update what I already have, as they're a known quantity and easy to get good speed out of.
I know exactly how fast an S12 can be in the forest and on the track. I've run against the black S13 and wasn't impressed by it. I like the sound of a NA Nissan 6 at full throttle, and I have a soft spot for Skylines. If it's workable, I might start on it. If not, there are other options.
Edited by afifield
I have a feeling the weight split is something horrendus like 70/30.
I haven't done my weights yet, as I have some new suspension parts to install first.
One of the local racecar fabricators doesn't think the weight split will be a problem, just have to get the weight jacking correct and the right spring rate. He suspected the rear would have to be set up very soft.
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
