Hi all,
I've been a forum member for a year or two, but have only been lurking until now. Apologies if this is in the wrong area.
I'm thinking about building an R32 GTS for rallying. You're probably wondering why N/A. Basically beacuse I can build it lighter and it doesn't need huge amounts of grunt. A GTR is out of the question because the minimum weight is way too high (1590kg)
Now for a heap of questions....
How light can you reasonably expect to build an R32? We're allowed to strip interior, remove sound deadening etc, but it would have a comprehensive cage and seam welding, plus a few other strengthening things done. The minimum weight for the capacity is 1030kg, but I'd be happy if I could get it under 1200kg. If I can't get it under 1200, I'd consider building a GTS-T instead.
What will an RB25DE safely rev to?
I've been told that RB25DEs have a cast crank. Are the RB25DET or RB26DETT cranks steel? If so, will one of them slot in, and does the RB26DETT have the same stroke?
Will GTR throttle bodies/manifold bolt on to an RB25DE head? If so, what throat and port diameters are they?
What should I reasonably expect to pay for an R32 GTS landed in aus, for rally only?
If anyone has a GTS rolling shell that they want to get rid of, I'd like to hear from you.
Also, a couple of years back, I met a bloke from the Blue Mountains that was running a dark silver GTS-T with GLT sponsorship (at a state motorkhana @ Nirimba). If he could make himself known to me, I'd be really grateful.
Thanks.
https://www.sau.com.au/forums/topic/158386-r32-gts-questions/
Dude, I am doing exactly this over in NZ.
I've got an R32 GTS Coupe that I'm building to rally.
Have a look here
http://www.skylinesdownunder.com/forums/sh...ead.php?t=52581
As far as weight goes mine was down to 1160kg, stripped out with the facory front seats in and about 50ltrs of fuel on board. My main worry about using a Skyline on gravel id the poor weight split between front and rear. I think an SR20 would help this a bit, but I love the sound of an RB @8000rpm too much!
The car now has a full cage in it and just a single race seat, so I must get around to weighing it again.
I haven't seam welded mine, but I have had the cage stiched into the pillars etc and will be building suspension braces too.
I don't know about an RB25, but a mate has an RB20DE-t thats revs happily to 8,500rpm with a stock bottom end. My car just has an RB20DE and it's happy to rev the same.
Hope some of this helps.
Cheers
Shane
Edited by screamin'
I'm guessing you'll come out at around the same weight after the cage
Yeah our production car GTR weights a little over factory now it has the cage in. But the rally rules are a whole different world.
Given you are looking for light, n/a and rwd, why not look into a S13 silvia na, they are dirt cheap and should be easy to get parts for. Also plenty of people race teh sr20 so there is lots of aftermarket/race stuff to choose from
Problem is that (IMO) the S13s are butt ugly.
Screamin - Any idea what the weight split is? Have you done corner weights?
I haven't managed to find the weight split info anywhere (not that I've looked too hard).
I'm assuming that the RB20 wouldn't be that much lighter than the RB25???
There's a lot more to consider when you are into motorsport, as to which looks good or not. Personally looks would be the least of my priorities. The main things to consider is balance / suspension and ease to work on these components.
No need to tell me that. I've been competing for 21 years and have picked up a few state and national class titles along the way. :)
If I'm going to spend that much time with it, I at least need to be able to look at it in the morning.
Having grown up with Renaults, most Jap stuff is easy to work on and (relatively) well balanced. Rather than go out and buy one, then find out it's all wrong, I'm trying to work out what the starting point is and what I can do to "fix" it's shortfalls. If it's too much of a hassle, I'll probably update what I already have, as they're a known quantity and easy to get good speed out of.
I know exactly how fast an S12 can be in the forest and on the track. I've run against the black S13 and wasn't impressed by it. I like the sound of a NA Nissan 6 at full throttle, and I have a soft spot for Skylines. If it's workable, I might start on it. If not, there are other options.
Edited by afifield
I have a feeling the weight split is something horrendus like 70/30.
I haven't done my weights yet, as I have some new suspension parts to install first.
One of the local racecar fabricators doesn't think the weight split will be a problem, just have to get the weight jacking correct and the right spring rate. He suspected the rear would have to be set up very soft.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
