I'll be there in the R.
Not sure if I'll put it on yet but chances are looking pretty good. Also depends on how I feel when I wake up in the morning and if the R is feeling up for a run >_<
So you'll be taking the prize for most power and i'll be taking the prize for least :sorcerer:
  • Replies 120
I wouldn't speak so soon. It all depends on whether the car will start in the morning, whether it get to Rays, whether I can be arsed getting on the dyno and whether it will hold together. It's only running street tune so I can't imagine it'll make any crazy AutoSalon figures. Guess we'll wait and see...
with the burnley tunnel closed, i'll probably not be going now - cbf going kingsway etc with all traffic diverted through that way.....
i reckon the tunnel will be cleared overnight and possibily open tomorrow morning. speaking as an emerg worker with smashes. they usually get cleared and the roads opened asap. itll be good to finally meet ya if u did show up. ill be there from 12 onwards with my awesomely bright yellow work shirt! :glare:
they were saying on ABC news at 7pm that the tunnel will be closed for "several days". So i don't like my chances of it being open tomorrow...it will most likely reopen on monday
Bit late I know But im new here :glare: the names Andrew I might come down and sign up if theres space might even chuck the old girl on the rollers before I start modding her. Shes a calsonic blue r33 with white rims someone better come and introduce themselves to me. SO is it like 120 all up?? 70 for mebership 50 for run??
Ohh and MAtt its Andrew scotts mate with the tx5 I now have an r33 :kiss:
Edited by zorb_rules
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
