Who was it? Jus copped sum flak for him...
Was driving in glenny and sum 50 yr old di(k in sum old cortina or sumfin stops next to me in the traffic and goes "people like you ought to be arrested" and i was like wtf... and when I asked him "what do u mean? why?" he goes "I saw you on TV the other day hooning about" and I was like pahhaahaha "no that wasn't me" *flick electric window*
ha...my neighbours always asking why i spend so much time on the car "is there something wrong with it" they keep asking :D
Personally i would have told them to mind their own ****ing business, and ask them how it ever effected their life whatsoever. People should keep their opinions to themselves unless its in their back yard or somehow effects them.
oh yer munky.. you *shoulda* said it was u and then putted off in your n/a and they would hae been like "man those cars aren't that fast... i am not sure what the whole thing on the show was about that car..crazy stories made up on tv" :D:)
Originally posted by predator666
ha...my neighbours always asking why i spend so much time on the car "is there something wrong with it" they keep asking :)
they are right... cause it's slow as fu*k
:D
Guest RaBZ3174
i was happly playing pool when i recieved a phone call saying my car was on channel 7.....i was like wtf? THEN who else but my old lady rings my phone saying im gonna sell your car when your asleep/ of course it wasnt me but it was good for a laugh!
hahah monkey i like the *flick electric window* effect
Least they got a commonwhore doing dognuts in the 2nd segment :D
i think the "blocking busy intersections" thing i thought was pure b.s. - most of the time its late at night out of the way of that sort of thing.
If anything I think that juz encourages the average petrolhead to go "hmmm, they sound cool, might try and find out where they are".. so if anything its going to backfire if you ask me.
The storm will die down a bit, but everybody will be back. They can't place cop cars everywhere.
Actually they should just make it legal.. choose a spot out of the way, block it off, and make everybody go there and muck around.. just have a few cops standing around (they'll love it) supervising to make sure nobody hits anybody.. and there, problem solved.. its no longer illegal, people still have their fun and its a bit more supervised.
Calder Friday nights is not enough, lets be honest about it. The other drags are an obvious symptom of that.
Every second friday with 150+ cars isn't enough... and you only get a few runs if that.
i agree with you there 100%.
They should be every friday night at the VERY LEAST!
and maybe another two days per month. It's not as it Calder is running at a loss with the ridiculous prices they are charging.
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
