Who was it? Jus copped sum flak for him...
Was driving in glenny and sum 50 yr old di(k in sum old cortina or sumfin stops next to me in the traffic and goes "people like you ought to be arrested" and i was like wtf... and when I asked him "what do u mean? why?" he goes "I saw you on TV the other day hooning about" and I was like pahhaahaha "no that wasn't me" *flick electric window*
ha...my neighbours always asking why i spend so much time on the car "is there something wrong with it" they keep asking :D
Personally i would have told them to mind their own ****ing business, and ask them how it ever effected their life whatsoever. People should keep their opinions to themselves unless its in their back yard or somehow effects them.
oh yer munky.. you *shoulda* said it was u and then putted off in your n/a and they would hae been like "man those cars aren't that fast... i am not sure what the whole thing on the show was about that car..crazy stories made up on tv" :D:)
Originally posted by predator666
ha...my neighbours always asking why i spend so much time on the car "is there something wrong with it" they keep asking :)
they are right... cause it's slow as fu*k
:D
Guest RaBZ3174
i was happly playing pool when i recieved a phone call saying my car was on channel 7.....i was like wtf? THEN who else but my old lady rings my phone saying im gonna sell your car when your asleep/ of course it wasnt me but it was good for a laugh!
hahah monkey i like the *flick electric window* effect
Least they got a commonwhore doing dognuts in the 2nd segment :D
i think the "blocking busy intersections" thing i thought was pure b.s. - most of the time its late at night out of the way of that sort of thing.
If anything I think that juz encourages the average petrolhead to go "hmmm, they sound cool, might try and find out where they are".. so if anything its going to backfire if you ask me.
The storm will die down a bit, but everybody will be back. They can't place cop cars everywhere.
Actually they should just make it legal.. choose a spot out of the way, block it off, and make everybody go there and muck around.. just have a few cops standing around (they'll love it) supervising to make sure nobody hits anybody.. and there, problem solved.. its no longer illegal, people still have their fun and its a bit more supervised.
Calder Friday nights is not enough, lets be honest about it. The other drags are an obvious symptom of that.
Every second friday with 150+ cars isn't enough... and you only get a few runs if that.
i agree with you there 100%.
They should be every friday night at the VERY LEAST!
and maybe another two days per month. It's not as it Calder is running at a loss with the ridiculous prices they are charging.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
