Hey guys,
My brother also owns an R32 gtst & when his engine is cold (left overnight) it hesitates on acceleration. If you keep the same peddle pressure it will hold back for a second then eratically rev harder as normal. Is this a normal thing? or maybe an issue? Having said that it operates fine once the car is at normal operating temp.
Thanks guys
https://www.sau.com.au/forums/topic/158452-r32-gtst-hesitates-when-cold/
http://www.skylinesaustralia.com/forums/in...hesitating+cold
the problem is in the ECU.
it is nissans way of warming up the engine with minimal stress on the engine. it goes into rich and retarded mapping up until something like 3300rpm or until you put your foot down a bit more.
do it next time you drive it cold, keep your foot at the same level and get to around 3300 and you will notice a sudden rush as the fuel and ignition maps have gone back to normal.
it is completely normal
That doesn't sound right. The manual advises to drive easily when cold, till temps are normal, so why would they make the engine run shit at low rpm, doesn't make sense. :rofl:
When warming up all tunes run rich with retarded timing, but apart from a lack of power, this should not effect drivability.
That doesn't sound right. The manual advises to drive easily when cold, till temps are normal, so why would they make the engine run shit at low rpm, doesn't make sense. :)
The above is just a quote from the link i provided.
I am not sure whether this is normal or not, although most r32's seem to have this problem. Would like to know the answer to this problem :D
its a common issue
i personally think its got something to do with the oxygen sensor needing to be warm/hot to operate
it seems like when its off boost it has no power at all, but when it comes into any boost at all it jumps into life like it normally would
neither do i.
check your fuel lines nisskid and make sure they arnt perished through and leaking
yeh i figured it would probably be a leak in the line, weird thing is, it only smells when its cold and running, so unless for some reason the leaks would close up when its warm, doesnt really make sense.
do u 2 have straight through exhuasts, cats?
Only have catback exhaust.
Uploaded a video of my daily cold start. Anyone have similar?
As you can see/hear, the key is turned for a while, then it jumps to life and falls back to zero. a blip on the throttle brings it back to life and idles normally...
Cheers
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
