Hey guys,
My brother also owns an R32 gtst & when his engine is cold (left overnight) it hesitates on acceleration. If you keep the same peddle pressure it will hold back for a second then eratically rev harder as normal. Is this a normal thing? or maybe an issue? Having said that it operates fine once the car is at normal operating temp.
Thanks guys
https://www.sau.com.au/forums/topic/158452-r32-gtst-hesitates-when-cold/
http://www.skylinesaustralia.com/forums/in...hesitating+cold
the problem is in the ECU.
it is nissans way of warming up the engine with minimal stress on the engine. it goes into rich and retarded mapping up until something like 3300rpm or until you put your foot down a bit more.
do it next time you drive it cold, keep your foot at the same level and get to around 3300 and you will notice a sudden rush as the fuel and ignition maps have gone back to normal.
it is completely normal
That doesn't sound right. The manual advises to drive easily when cold, till temps are normal, so why would they make the engine run shit at low rpm, doesn't make sense. :rofl:
When warming up all tunes run rich with retarded timing, but apart from a lack of power, this should not effect drivability.
That doesn't sound right. The manual advises to drive easily when cold, till temps are normal, so why would they make the engine run shit at low rpm, doesn't make sense. :)
The above is just a quote from the link i provided.
I am not sure whether this is normal or not, although most r32's seem to have this problem. Would like to know the answer to this problem :D
its a common issue
i personally think its got something to do with the oxygen sensor needing to be warm/hot to operate
it seems like when its off boost it has no power at all, but when it comes into any boost at all it jumps into life like it normally would
neither do i.
check your fuel lines nisskid and make sure they arnt perished through and leaking
yeh i figured it would probably be a leak in the line, weird thing is, it only smells when its cold and running, so unless for some reason the leaks would close up when its warm, doesnt really make sense.
do u 2 have straight through exhuasts, cats?
Only have catback exhaust.
Uploaded a video of my daily cold start. Anyone have similar?
As you can see/hear, the key is turned for a while, then it jumps to life and falls back to zero. a blip on the throttle brings it back to life and idles normally...
Cheers
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
    • This thing did a 1:20.88 at Winton on the weekend which is f**king rapid.  Well done mate, your driving has really gone up a few notches not much left on the table now! Good luck at WTAC.   https://www.facebook.com/share/r/1MHyZQBqZ2/
    • Are you guys meeting up with the Sydney SAU guys at Lambton Pool Carpark or heading straight in?
