yeh mine does the same, it would seem most do this, im just more interested in the fuel smell part, anyone here have a straight through? Rekin urs sounds pretty quite so i would assume uve got a decent exhaust on urs.
mine does that too.
i dont mind. its like a reminded not to go too fast when its cold :(
after about 1 or 2 minutes of driving. its completely fine.
hhahah oh so true mine does the same thing and it is a reminder a little, only eva does it first thing, wat about if u start ur car on a hot summer day wit hot air im pretty sure from memory it does it but alot quicker to jump to the pace,
let it warm up u dont notice shit
AAC vale cloggin its understandable to
U cold start issue i had was fixed wit a new AFM
cheers brett
Edited by (oo\__4Door__/oo)
got a apexi catback exhaust :P
Ive had my afm checked, o2 sensor checked, aac valve cleaned, pod filter cleaned, fuel pressure checked. Not sure what else to check? haha
There must be some common fault we seem to all be overlooking which causes this :s
Yeah i think that is the case, i dont think its a problem it seems normal. Others probably dont notice it because they warm up their car more than we obviously do. Therefore they dont experience this problem. I gurantee once winter hits this topic will be covered many times again.
I have the same deal (the cold start, have to blip the throttle once to keep it running) and the the hestitation. Mine does it at 2k if I don't let it warm all the way up (which can take like 10mins if not driving!). I figure at 2k it's just limp mode because it's still cold. I let it idle for minimum of 30 seconds before taking off and just take it easy and shift below 2k until my temp guage is at halfway then it's all fine. Usually she gets enough to as it takes me to smoke a cigarette in the morning to warmup, which barely moves the needle, then I start driving her.
P.S. This is on an RB20DET :)
mine is the same, hesitates on startup then runs like crap for a bit... i think it pings sounds like popcorn popping under the bonnet, has no power and feels like the coils are f**ked, a quick squirt in 1st or 2nd around the corner makes it go away
nisskid mine does this also, i have straight through exhaust with a "special" cat
except if you stand outside the car it burns your eyes! still seems to run fine at
normal operating temp and has been tuned so maybe just an r32 thing??
alright thats good to know, cheers.
think knock sensor.. consult shows timing going to 7 degrees and not altering while accel, then past a certain point, jumps to 20-30 degrees. suspect knock sensor problems causing the issue. at first thought it could be coolant temp sensor (causing rich run to make sluggishness) then i plugged the consult in.
i can up a file if anyone wants to see it. i am on a S13 swapped RB20. anyone with a really fresh RB20 having this problem? maybe the sensor rattled loose in the case, or theres an abnormal rattle in the motor when its cold....
oh yes, i have 2 ECU's one is chipped and tune the other is unchipped stock. both ECU do the same thing
Edited by Johnzm
http://www.skylinesaustralia.com/forums/in...showtopic=12923
anyone care to try this? my car is not running at the moment (clutch pedal exploded:(
also http://www.skylinesaustralia.com/forums/in...ation&st=20
Edited by Johnzm
check the thermostat...
my car used to run shit for a good ten minutes every morning, turned out the thermostat was rooted and allowing water through the radiator all the time... my piston rings were also cactus and that didn't help:/
ive run my car with 4 diff thermo's, 180's and 170's. also with no thermo at all, and also with "water restrictor" (metal with a hole in it to slow down total flow, but no thermo element)
nothing helped this problem except getting it hot faster, which would be a totally clogged radiator and a thermostat LOL
  • 4 weeks later...
just bumping this thread as i've found a temporary solution that i use now...
try this:
- start the car
- let it idle for 30sec - 1min, give it a blip of the throttle to check that its got its usual flat feel to it
- turn the car off
- immediately turn the car back on
- blip the throttle again... notice the flat feel is gone?
i was getting annoyed by having the car jerk around for a few minutes while i had passengers in it and its very annoying. this way the car drives perfect. its no excuse to stop driving sedately while the engine warms up, but it restores the dormal driving characteristics in the mean time.
must be something to do with the ECU sensing that the engine has been off for a certain period of time. thus, when the car is turned off and then on again, the ECU thinks its been on recently and uses the normal timing and fuel maps...
keen to see if it helps others... post up your results...
cheers,
Warren
well i seem to be having the same problem as everyone else...tho my car starts perfectly ever morning..but its the drives...ill be driving n as soon as it reaches around 3000rpm..it feels like its got no power...i usually just keep driving till the temp needle reach half way n its gone..that usually take around 5 to 7mins
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
