Hi All,
Ever since I have owned my R33 the drivers side electric motor hasn't worked, and I noticed today that the de-fogging function on the glass doesn't work either. Passengers side is fine though..
Have had a look in the fusebox but it all seems in tact. Any ideas people?
:D
chicane
:burnout:
I had a look on the weekend, i can remove the mirror from the door, (pop off the plastic cover and undo the 3 screws), but how do i get in behind the plate glass? i tried popping it off but I didn't wanna bust the glass ;)
chicane, i have the same prob with my passanger side mirror which made a bad noise when folding out once then never folded out again... but still folds in, i just pull it out by hand, drivers side perfect. I've also tryed pulling it apart and got to the point where u are, ive been meaning to ask nissan for a look at the photos of it, also just curious about the mirror defogging, do you have a switch to turn this on ?
cheers...lenno
The mirror glass should just pop off - you have to kinda pull quite hard, but it does eventually come off...
There are several screws holding the motor unit in place, just undo them and then you should be able to remove the entire unit from the cover.
Dave, tnx for your reply.. I'll have another look tonight to see if I can pop it out..
Lenno, Probably suggest you do what Demon Dave has suggested, Have a look at the motor.. I'll take some pics with the digi cam may be able to help ya.
As for the defogging, I read in a Skyline Manual that when the rear demister is put on, the side mirrors have defogging built into them.. and just the rear demister button to the right of the hazard switch turns it on.. On a real cold/foggy morning if I park on my lawn, the side mirrors get fogged up - The passenger side one clears really quickly but the drivers side remains the same..
Cheers
Hi Lenno,
I have the manual in front of me at the moment: It's the JPNZ R33 Skyline Drivers Manual.. (mate lent it to me, was in his glovebox when he got the car). Page 57:
"Heated Mirrors & Rear Window De-Fogger"
The super sonic mirror will heat up to defog the mirrors. Push button, shown to operate super sonic option first mirror will vibrate to remove any water from the mirrors then heater will switch on. If mirror gets old and scratched and isnt working sufficiently contact nissan to have specified mirror replaced. Dont clean mirrors with an abrasive cleaning material"
also
Pg 51.
"Heated Door Mirror"
When the Rear De-Fogger is pressed the Heated Mirror System will automatically turn on to melt away any ice on the mirrors. This system will automatically turn itself offafter 15 minutes or you can press the Rear De-Fogger switch again to turn off the system manually. Do not try to use the Power Mirror Function while the mirrors have ice on them, always use the heated mirror system first."
Hope this helps!!
chicane
PS. I have a feeling the reason the mirror isnt working properly is because it was bodged by the compliance people when they changed it to a flat glass mirror.. Grrrrrrrrrr :)
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
