I was wondering what the differences are between the HR33, ER33 & ECR33 (specifically for the R33 GTS25, but for all types would be handy to know also). Is there any physical change in body shape?
Also, did the R33 GTS rb25de come with an LSD? Is there any way of telling from the firewall plate?
Thanks
https://www.sau.com.au/forums/topic/15847-what-do-the-model-numbers-mean/
haha, i spose that is more than a possibilty, im the first australian owner of my car so i know no history of it prior to that, but the guy that put the alarm in said it had the turbo wiring loom so i spose its a possibilty?? is there neway to tell?
i mean it does have the non turbo speedo, but it also has hicas and no abs, though i have never felt nor seen the hicas working, is there nething unique that only the turbo would have? also the air box is missing a bracket.... though it has non turbo brakes. Its got me thinking though.
  • 4 weeks later...
hehe have you seen what HICAS does to a kakimoto widebody? it turns the wheel like 2 degrees, which, coupled with the 316 wheel size make it scrape along the guards... so much so that you gotta take hicas out on them or you can't drive it.
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
