gday guys, just curious as to what type of standard parts you are using in ya car if it is making big power. say 300rwkws+
things like standard pistons, rods, rings, water pump, oil pump, cams etc.
cheers james
https://www.sau.com.au/forums/topic/158510-big-power-using-standard-parts/
well my car was running 12psi 55oc inj's, and exhaust making around 200 awkws. including a oil restrictor and newer oil pump.
when it died that is.
Edited by Turbz_13
  • 3 weeks later...
this is all good to hear, i have had my rb26 rebuild with eagle rods and acl pistons and rings but using a new standard r32 oil pump(early) and was looking at bigish kinda power. say 350awaks
Rebuilding your engine for that kind of power and not upgrading your oil pump/oil pump drive is crazy and now leaves your new engine with a serious weak point
Agreed, adding to that water pump, tensioners etc etc
the engine has the lot exept the new oil pump, well it does have a new pump. just an OEM one. i was running out of fund with the rebuild rather quickly so an oil pump like a nismo, trust, jun etc was out of the question.
wasnt too keen on the n1 as i have heard about 50% of them that are installed seem to fail, (i have heard this not saying its the truth or they are bad or what every). which actually turned me off the path of using one. so rather than wasting the cash having everything prep'd for an n1 oil pump and it failing the standard pump was decided. as im not looking at increasing the rev's over 7500. it was always out of the question in my mind to increase it that far.
eventually if i decide on going big power. ie 400+kws at the wheels i will have to budget to replace my oil pump with a decent name one. and i guess then i will need my crank collared as well. so im guessing another engine out job. so 5k for the lot this time?
Edited by Turbz_13
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
