gday guys, just curious as to what type of standard parts you are using in ya car if it is making big power. say 300rwkws+
things like standard pistons, rods, rings, water pump, oil pump, cams etc.
cheers james
https://www.sau.com.au/forums/topic/158510-big-power-using-standard-parts/
well my car was running 12psi 55oc inj's, and exhaust making around 200 awkws. including a oil restrictor and newer oil pump.
when it died that is.
Edited by Turbz_13
  • 3 weeks later...
this is all good to hear, i have had my rb26 rebuild with eagle rods and acl pistons and rings but using a new standard r32 oil pump(early) and was looking at bigish kinda power. say 350awaks
Rebuilding your engine for that kind of power and not upgrading your oil pump/oil pump drive is crazy and now leaves your new engine with a serious weak point
Agreed, adding to that water pump, tensioners etc etc
the engine has the lot exept the new oil pump, well it does have a new pump. just an OEM one. i was running out of fund with the rebuild rather quickly so an oil pump like a nismo, trust, jun etc was out of the question.
wasnt too keen on the n1 as i have heard about 50% of them that are installed seem to fail, (i have heard this not saying its the truth or they are bad or what every). which actually turned me off the path of using one. so rather than wasting the cash having everything prep'd for an n1 oil pump and it failing the standard pump was decided. as im not looking at increasing the rev's over 7500. it was always out of the question in my mind to increase it that far.
eventually if i decide on going big power. ie 400+kws at the wheels i will have to budget to replace my oil pump with a decent name one. and i guess then i will need my crank collared as well. so im guessing another engine out job. so 5k for the lot this time?
Edited by Turbz_13
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
