not at the moment, the rebuild burnt a hole in my pocket. but i may get the crank and oil pump together. then just have the sump pulled off and the crank changed and oil pump changed.
may even get a harmonic balancer, but see what happens. as i have NO intension of reving much over 7500!! well not for the moment anyways!!
but wont they require the balancing???
i fully understand as i have missed gears before and it hit the rev limiter. which is just over 8000rpm in the 32's i thought. this was before the rebuild.
but dont most decent engine management systems these days have rev limiters as a function, im sure the power fc does. so to avoid over reving wont setting the rev limit at say 7500rpm work in the case of missing a gear??
cubes what typre of oil pump are you running? you have a high powered engine?
I built mine up over 2 years ago when JUN crank collars were over $600 + fitting. Now they are down $130 ish so it is very very much worth throwing one on as $130 is next to nothing in the grand scheme of things.
I had my PFC revlimit set to 6200rpm due to a valve spring issue, a missed gear change in to fourth and saw it hit just under 8500rpm within a blink of the eye. I find the pfc's rev limit isn't crash hot on free rev's. In gear acceleration its fine.
I run what was supposed to be a rb25det pump that had zero wear on it; I see roughly ~6kgcm/2 (85psi) over 3000rpm and 7kgcm/2 (100psi) over 3500rpm so it has healthy oil pressure.
Yeah, but cubes, you have fitted a collar and then run a 25 pump which has the thin drive, and you also keep the revs down due to the 3lt bottom end. In your case i'd say it wasn't needed.
If you were reving to 8k regularly or running a pump with the thicker drive on the stock collar i'd say otherwise, but in this case i'm looking at a lot of money that could have gone towards beer and hookers.
Not denying that it's a known weak point in the r32 rb26's, but if revs are kept reasonable (under 7.5k) then there shouldn't be an issue. There aren't that many rb25's reporting failures with their factory 7k ish limiters and they all have the thin collar.
Agreed but the colars are so damn cheap these days. You'd be pushed to get a decent cim :P hooker for the price of the collar + fitting.
I don't run a collar as it was out of my reach at the time.
The ONLY pump that has the same width drive as the std cranks drive is the RB30E pump.
The RB20det runs a wide crank engagement BUT the inner gear is a touch thinner and from memory it also had one extra lump than the rb25 pump I compared it to.
All the other pumps, RB20, rb25, gtr, n1 etc all have a drive that is much wider than the cranks drive.
The RB25 pump I have looks exactly the same as a GTR pump.
I'm sure you can guess which one is the rb30 oil pump and which is the 25t pump. :)
:P
What my point really is...........
The topic of the thread is 300rwkw+.
An rb26 with 300+rwkw doesn't exactly spool such a sized turbo early. Turbo comes on hard say 5000rpmish?, thats a 2000-2500rpm power band. Drop it in the lower gears and its even less. :S
If its being rebuilt.. Why not. :happy:
I hope you lot can see what I'm getting at. A car with a small power band is shit to drive and slow in its lower gears.
what sort of oil pump was the first picture of the drive out of?
i understand what ya saying. but dont the early r32 gtr oil pump drive sit alot closer to the block than the ones that require the collar? and with the collar does that require the crank to be machined then fitted or does it slip over the original drive?
It could be either an Rb25 pump or rb26 pump. Not sure.
Oil pumps.. Basically all the same apart from slight differences in width for higherflow etc etc.. All the pumps gear width is much larger than the cranks engagement lug.
Another option is to grab the R33 GTR crank as Nissan rectified the fault in the R33 RB25DET Series 2 and R33 GTR's.
Here's a pic of a gtr crank and one with the collar. The Rb30 crank had the same small engagement lug as did the old rb20; no difference in positioning. Unfortunately it does require slight machining for fitment.
ah so i may have been told a load of crap. therefor the crank on the right hand side(of the picture) is the type of crank that is in my rb26(older 32 gtr)? because i was told that the oil pump drive widths were exactly the same, just the newer one sat further out from the block, hence the witness marks on the r33 gtr pump that was in the car when i brought it.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
