i like my rims to much to get rid of em though i cant find em anywhere in aus and i might lower it a bit not much though i can hardly get out of my driveway as it is gotta get my mate to shave my driveway down a bit haha
Thats another problem... cause you cant find em anywhere, what if you have an accident and damage it beyond repair? you'll have three whells... not much good to you ey?
Now try to imagine the effort it is to sell only 3 wheel to someone and then explaining why. No one wil take them and then you'll be stuck with them forever... FOREVER!!!11!
anyway
