post-28634-1172657408.jpgMitsubishi 6A12G MIVEC V6
RPW carbongraphite decompression head gasket (approx 9.0:1)
Custom Garrett 450hp hybrid ballbearing turbocharger (T28/T04 hybrid)
Custom 2.5' mandrel-bent dump pipe
Custom stainless exhaust manifold
Custom turbo intake feed pipe
Custom stainless intercooler piping
Custom 2.5' mandrel-bent mild steel exhaust (cat-back)
Custom Genesis-tuned Microtech LTX-8S ECU
6x Bosch 480cc injectors
Walbro 500hp in-tank fuel pump
Apex'i air-pod filter
Apex'i AVCR Boost Controller
Custom front mounted air-to-air tube & fin intercooler
HKS Super Sequential Blow-off Valve
Samco silicon hoses
Braided oil lines
Modified inlet manifold
Custom oil breather tank
NGK Iridium spark plugs
Speedflow anodised hose fittings
Custom radiator and air filter heatshield (in carbonfibre)
Engine modifications worth all ($9,000)
DRIVELINE:
Factory 5-speed manual (modified with stronger internals)
Exedy Hyper single plate heavy duty clutch with lightened & balanced flywheel
Rare factory LSD
WHEELS / BRAKES / SUSPENSION:
17' BuddyClub P1 Racing lightweight Japanese alloy wheels with Bridgestone Potenza G3 tyres ($2,000)
Sheepdog Prof-Sport springs ($350)
Cusco upper strut tower brace front & rear ($500)
BODYSTYLING:
Custom aero front bumper (GPvR/DCuatro hybrid)
Genuine C-West carbonfibre front canards
Custom modified Kansai wing (ala Porsche GT2-style) ($2,000)
High-Intensity Discharge 7500K headlight conversion **SOLD**
I.C.E:
Panasonic MP3 head deck
1x Cadence Q4000 4ch amplifier
1x 12' Phoenix Gold Tantrum 12D subwoofer in sealed enclosure
Kenwood front coaxial speakers
System worth ($1,000)
INTERIOR:
EL gauges ($200)
Defi Heads Up Display ($350)
Pivot turbo timer
Razo gearknob & pedals
Sabelt harness pads
AVCR boost controller ($400)
Factory genuine Momo airbag wheel
For that enthusiust who want to be different,
Stiil has more power left in the turbo roughly another 150KW, needs internals done.
Price: $17,500
Alot of $$$ spent, true sleeper!
RWC & 12MONTHS REG.
post-28634-1172657408.jpg post-28634-1172657580.jpg post-28634-1172657687.jpg post-28634-1172657812.jpg post-28634-1172660889.jpg post-28634-1172660985.jpg post-28634-1172661119.jpg
  • 1 month later...
  • 1 month later...
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
