  • Replies 68
Good idea a5h.. Go out and buy a key (i got one.. hehe) and go buy some polish, wax and polish your car up. I promise it will look better all smick and clean that with some lights on it which are just going to detract from the skyline it self.
You already have a unique car.. :P
Who cares what people think about your car mate. There will always be someone who will bag your car no matter what you do.
If you wanna whack neons on your car, then you should. As long as your car's got a bit of credibility, then you should be ok!
I would go neons over a key or petrol cap anyday.....
i have a single blue neon above my number plate (under the rear bar) only the glow is visable and it lights the road up blue along the back of my car as well as making the number plate look cool.
heaps of ppl tell me they like it. and i havent been pulled over for it yet.
i think some neons look good as long as its a really low car and as long as you cant see the neon tube.
it looks best if you can only see the glow.
i havent got a pic of mine a the moment but will post one asap.
I like neons. i had a set put onto my sister car and its looks very nice if i can be fu*k one night i take some pics for you boi.
(by the way it anit a skyline its an astra_dont laught)
and yeah the cops dont seam to like the neons much? heheh but i love driving with them on and see all the people stair at you like your car is on fire or something heheh very funny.
Also attracts alot of dickheads tring to drag you.
Installing is a pos any one that has a basic idea about anything could do it. cost around $200 for the kit and if u get them install around $350 all together (i would say get them install cuz if they crack or u hit something and they brake the get repair FREE)
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
