R33 Gtr Rims Wheels
  • 3 weeks later...
any chance you would you be interested in swaping for another set of R33 GTR wheels?
ive got a set that im trying to sell that have been fully polished on the face, so they look like chrome wheels.
ive been wanting to get a set so that i could get them powdercoated. but i dont want to do it to mine because they have been fully polished
adrian
Edited by Sticky
BUMP still FS had like 10 people interested but all evaporate for unknown reasons!! first to offer 1100 can have them, please dont offer under 1100, will send if required for additional cost,
The problem is mate that the condition is very poor and that is going to put your average joe buyer off because they have to stuff around with rim repairs etc. If you want them gone in a hurry in that condition you might want to revise the price.
I'm sure eventually you can sell them but as far as unknown reasons go - i think the reasons are quite clear.
the condition doesnt look poor to me, they have some slight gutter marking around the edges but the spokes arent scratched.
they are almost as good as my R33 GTR wheels
the price is very good considering condition, the only reason it wouldnt be is if they were buckled
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
