seeing as we dont have a "handling" forum i'll ask it in here...
i didnt know i had adjustable shocks til i went to see troy all those many months ago in regards to getting a pod filter to which he informed me it had... i knew the fronts were so back then i checked the rears and didnt see a dial like the fronts had so thought they must be stock.
now 2 weeks ago when i went and got those GTR guards mike told me the rears have a dial on them which u use to adjust it... i checked it then and yes they do... they have the word "Potenza" on them... now i only thought they made tyres? dunlops init?
also i started turning the dial towards the "hard" direction and i dont know how far im meant to go cause it made like 10 clicks... should i keep going? :D
https://www.sau.com.au/forums/topic/15858-shocks/
bridgestone make shocks? i thought they just made tyres?
i want it on hard hard but it doesnt seem to stop... the fronts have 4 settings but the nob seems to keep turning... will it eventually stop? :D
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324376
well they didnt go much further... so i would assume thats as hard as they get... will take it for a spin and see if it makes a diff...
btw would have the fronts softer than the rears cause understeer? cause i get a lot of that.
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324385
I've got HKS 'adjustables' in my 32, but how do I adjust them? I haven't got a dial. The best I can figure is I need to hold the bottom part steady, and twist the top.
The guy at the yard told me they were adjustable. They're hard as anything and I want to soften them up a little for road use.
See pic. sorry for the quality of the pic...
Any help appreciated...
46n2
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324427
They look like stockers... aren't all HKS one purple topped?
and nark, soft front / hard rear promotes oversteer (i think). By having the front softer it allows the front to 'dig' when you turn thereby giving more bite. The hard rear then comes around and you're looking back at last week :P.
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324443
I think so... better check with someone who actually knows... i'm just speculating. I just thought about it the other way around and i have reasoned that this could promote oversteer too...
Ahh, like Austin Powers i think i've gone cross eyed. lol
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324463
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
    • I have a wheel cleaner pokie thing which is a glorified microfibre rag on a stick, and there is not sufficient clearance between the caliper and the barrel to clean that section. I just roll the car forward 500mm and have another shot at each wheel.
    • The "rag on a stick" is a easy way to fit in between the wheel spokes into all of the barrel Albeit I do have 10 spokes on the MX5 which limits the access to actually jam my hand in to clean the barrel, but it was also makes much easier to clean the 5 spokes on the Dunnydoore with it as well, as you don't have to worry theΒ  caliper getting in the way if you have at least about 15mm space between the caliper and barrel This of course depends if you actually have the clearance between the barrel and caliper, and the amount of OCD you have to get the barrels as clean and shiny as the face of the wheel The thing is bendy as well so you can actually shape it to conform to the inner lip of the barrel Β
    • FWIW, as well as a basic immobiliser/remote unlock (all basic units give you those 2 things), I would also install a 4g tracker in any car I cared about. Just hide it anywhere that won't be found in a rushed look and preferably get something with a built in battery backup so it stays online for a while when the battery is removed or flat While its not a car, when our car trailer was stolen in that den of crime Sydney about a decade ago, the cops were watching from the bloke's neighbour's lawn within about 2 hours until he started swapping the plates and putting up the gumtree ad.Β Β  Obviously it is still not undefeatable (eg parking it up for a few days somewhere without sky sight) but it greatly improves your chances of getting it back quickly and with less damage
    • Instead of magic keyphrases I wonder if something can be done with auto complete. Similar to how user names are handled already. When you type '@' and follow with letters, it'll search across all usernames. It might work to have the same for forum topics. Some key to trigger it and then text search across all thread names and it'll insert the name and URL when pressing enter.
Γ—
Γ—
