seeing as we dont have a "handling" forum i'll ask it in here...
i didnt know i had adjustable shocks til i went to see troy all those many months ago in regards to getting a pod filter to which he informed me it had... i knew the fronts were so back then i checked the rears and didnt see a dial like the fronts had so thought they must be stock.
now 2 weeks ago when i went and got those GTR guards mike told me the rears have a dial on them which u use to adjust it... i checked it then and yes they do... they have the word "Potenza" on them... now i only thought they made tyres? dunlops init?
also i started turning the dial towards the "hard" direction and i dont know how far im meant to go cause it made like 10 clicks... should i keep going? :D
https://www.sau.com.au/forums/topic/15858-shocks/
bridgestone make shocks? i thought they just made tyres?
i want it on hard hard but it doesnt seem to stop... the fronts have 4 settings but the nob seems to keep turning... will it eventually stop? :D
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324376
well they didnt go much further... so i would assume thats as hard as they get... will take it for a spin and see if it makes a diff...
btw would have the fronts softer than the rears cause understeer? cause i get a lot of that.
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324385
I've got HKS 'adjustables' in my 32, but how do I adjust them? I haven't got a dial. The best I can figure is I need to hold the bottom part steady, and twist the top.
The guy at the yard told me they were adjustable. They're hard as anything and I want to soften them up a little for road use.
See pic. sorry for the quality of the pic...
Any help appreciated...
46n2
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324427
They look like stockers... aren't all HKS one purple topped?
and nark, soft front / hard rear promotes oversteer (i think). By having the front softer it allows the front to 'dig' when you turn thereby giving more bite. The hard rear then comes around and you're looking back at last week :P.
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324443
I think so... better check with someone who actually knows... i'm just speculating. I just thought about it the other way around and i have reasoned that this could promote oversteer too...
Ahh, like Austin Powers i think i've gone cross eyed. lol
https://www.sau.com.au/forums/topic/15858-shocks/#findComment-324463
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
