To SAU'ers, I NEED HELP DESPERATELY???? :)
*My car when i try to start my car it wont start, turn ignition but no turning over try again and it might start or otherwise turn turbo timer off and it might start?,when it does start it sounds like its on 3cyls.... barely turning over for like 6secs, then it will fire up and idle at 1000rpm like normal.
(Battery tested 100% ok and is only 4mnths old, and Alternator charges perfect too).
*When idling it sounds like it hunts / stutters/ misses? idle alil erratic (drops maybe from 700 to 650 then back to 700)
*It uses alot of fuel, i dont know how much per kilometre but to drive from mtgravatt to the city and back uses nearly half a tank.
*When accelerating the car doesnt blow any black smoke out the back of the exhaust like alot of skylines i've seen, but when u take ur foot off the accelerator to slow down or change gear. The car backfires / pops alot and blipping the throttle can make it backfire / pop aswell.
*The hicas light started flicking on and off like 2times a day and it killed the power to my headunit aswell when it happens. This has caused the car to stall twice aswell but thought maybe it was to do with my amp/sub install so i disconnected the wiring etc and waiting to see if it happens again.
My Car Specs
1989 R32 GTST Coupe
6 x New NGK Iridiums (for standard boost)
HKS Turbo Timer (came with car from japan)
HKS Pod Filter
Autometre BOOST gauge (Mechanical)
Standard BOOST (spikes to 10/11psi)
Standard BOV
Standard Sidemount intercooler
BEE-R Catback Exhaust
Hiflow Cat
Standard Dump etc
ANY HELP IS VERY APPRECIATED
QLD SAUER
[ BOOSTA ] aka PETE :)
Edited by BOOSTA
Sounds like the ECU is in limp home mode. What have you been doing recently under the bonnet recently? Knocked the AFM plug perhaps?
Anyone around your area got a consult reader? That will enable you to check the sensors and identify the problem.
:P cheers :kiss:
Sydneykid, thankyou for the fast reply....
Whats the limp home mode? and whats a consult reader?
I havent really touched under the bonnet in awhile only to change the plugs and clean the AFM with a electrical contact cleaner? but it was all pluged back in. The only thing i have noticed was the plugs that plug into the coil packs ( the yellow plastic holders inside that hold the 3 wires have started to crumble )
Could this possibly cause any of the problems?
I just dont understand the reason when u accelerate it seems fine and quick but yet no rich puff of black smoke ever.... i've never had any of that even when i bought the car 9mnths ago?
Thanks BOOSTA (pete)
Thanks Waz, I'll go and recheck the afm plug now.....
Are standard 32 bovs quite loud? a police officer pulled my partner over and said my standard bov sounded too loud like aftermarket and told her it had to be removed :S
cheers Pete (BOOSTA)
Your standard plumb back bov needs to be removed? Thats the most ridiculas thing ive ever heard.
yeah i know.... i was looking at her like what the hell, how do you remove a standard item and replace it with what? a bag of potato chips?
Just wish i could get this car sorted... the car pops and backfires every gear change ! its damn annoying and embarassing!
mine does that too....
havnt fixed it yet....
getting it retuned shortly tho...
ive replaced
coils, plugs, cleaned AFM.
yet to change 02 sensor...thats comming soon...
but mine runs rough all the time, changing gears, down shifting etc.....
ever since i had a major service done, perhaps the timing is out...
dont know.
yeah it sucks huh,
The thing that confuses me is the car doesnt stutter or miss when u put power down, only when it idles does it miss/ irregular idle? it pops and backfires when u change gears or come off the accelerator? I'm confused as all buggery. I dont know what to do,
when I get some more money then i'll prob take it somewhere but things are pretty tight for me at the moment. So any help to try and eliminate stuff is great for me.
cheers Pete
ps.. good luck with trying to sort out ur car JVP
Just came back from checking AFM, unplugging it and cleaning and replugging back in and still no difference. The plug clicks in place and still no difference, the car still idles like crap nearly stalling.
I checked the fuel pump and the lines, there pulsing away with fuel, check the ecu and 55 code came up ( no malfunctions ).
Im kinda empty for ideas.
I have 2 sensors in my exhaust, 1 near the dump pipe and then another near the cat? is that all normal?
LOL Plz help us!!!
Cheers Pete (BOOSTA)
To SAU'ers, I NEED HELP DESPERATELY???? :D
Hey mate, its an outside chance but do you have an aftermarket steering wheel fitted???? mine came over from japan with a nardi wheel on it which i was most pleased about, but after a while my hicas light started coming on at random times mostly when my speed was over about 80km. It turned out to be the hicas sensors in the steering colum had moved around... i imagine when the aftermarket wheel was installed. Basically what this was doing was telling the computer the wrong signals for the hicas to work and it seemed the faster you went the computer figured that the readings it was getting must have been bullsh%$t and put on the hicas light. If its not this it could well be that the fluid in the hicas resovour (damn i need spell check) is low.
just my 2cents ... hope it helps :D
Hey Guys
Jvp and Sanger thankyou for trying to help me out, I have a standard steering wheel and i dont think its ever had a aftermarket wheel??
But i've had to take off the interior plastics around the steering wheel and dash as my odometer has stuffed itself and then where the plastic connects to the speedo cable its all cracked there too.
But when i took the plastics off, i noticed alot of unplugged wires and connectors, theres alot of wires going to fuses and connectors etc????
I have a HKS turbo timer and theres wires to that and other stuff aswell.
Im really starting to hate this car.... actually thinking of just getting rid of it. I cant afford time at a mechanics as the money I had saved up I gave to my parents to help them out with stuff. If I had the money I'd take it a workshop but when u pay $260 a week rent and you earn $480 p/w it just doesnt leave much for toys.
Thanks anyways guys
I'll just have to either try and sort it out somehow or sell it as is!
Cheers BOOSTA (pete)
No worries mate... i know how you feel my car has a few problems at the moment and you just feel like selling it when its not working.... But when they are running well it makes you remember why you bought one in the first place!!!!! hope you can sort it out!!!
thanks sanger.... yeah i know how much i'd miss the car when its gone but I just am stuck in a hole atm.... I mean when you go for a drive these cars just make you forget about all your worries and just think about the drive.
I dont mind most problems its just come at the worst possible time!
Cheers BOOSTA (Pete)
hey colbs,
Unfortunately Im just not that well known in the SAU qld (Brisbane) circle as i came from the old skool group of which many have left... I dont think many people would wanna give a stranger there ecu to borrow :laugh:
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
