bring it to the workshop near ur place. if u in mt gravatt i knw a good mechanic around there which is near the JB HIFI. i used to work there. is locate in front of the pool n snooker shop. if u knw where.
Did u check the coil packs see is it burn ? i think i had tis kind of problem before in my work place's customer's car. but is R33. yea i just hate the hicas light alway on and off.
but , if is about the idle. pull the coil packs n check whether is burn or not. if im not wrong one of my customer's car had tis problem. we check all the sensors n nothing wrong with it and end up is the intake pipe which is from air filter to the turbo pipe. The reason of the pipe is because of the heat make the pipe get softer n when u the pipe will b squire. Im not sure if is the same problem i had in customer's car.
Just bring it to the mechanic near the JB HIFI area. i already lost his phone number and forget what's the workshop call.
Good luck
Mick
Thanks halo,
Yeah thanks to alot of people who have given me some great opinions guys..... thankyou alot.
I think im gonna start by tracing these wires in the steering column and make sure there all connected up and not cut / faulty. I have no resivor in my 32 at the back so im guessing my hicas fluid is from the PS resivor which is full.
As for the idle im going to first clean the AAC valve and reset the base idle etc, change fuel filter and then if its still the same, take the coils out and check them thoroughly and maybe also cover them in industrial grade silicon just incase there starting to arc out.
I think the connectors for the plugs that connect to the coil packs are rooted as the little plastic insides have crumbled up? has that happened to anyone else yet?
Do i just hunt for a 2nd hand set of leads/wires with the connectors on? or can u buy those plastic bits new from nissan?
Also picking up a 2nd hand speedo as mine has split the plastic housing at the back and causes the speedometer to jerk about sometimes and plus the odometer has stopped working :S
Thanks guys for all the advice and help.....
Its great to know i can always ask the SAU family for some help
Cheers BOOSTA (pete)
for the spedo cable u cant get the plastic bit. u have to change whole spedo cable which u can get 2nd hand or from nissan dealer which will cost u too much so juz go to wreckers and get them. because of the speedo cable cause u the add metre stop working.
try getting your injectors cleaned and see if it makes any difference, my r32 was doing the same thing - drives fine idles shit, when i got the injectors cleaned it fixed it. could also be the coolant temp sensor, the car thinks its cold all the time so its always running rich, might be worth changing, theyre pretty cheap.
Hey Guys,
Thanks so much to all who have replied, i have quite a good list of things to start checking over and one by one will knock them off the list.
I dont know what i'd of done if it wasnt for the help from SAU, Does anyone know a good way to check out cooler piping to see if its leaking air anywhere? Because my standard bov is bloody loud, sounds like a turbosmart atmo vent one even tho its plumbed back ?....
THANKYOU !!!
My List to check......
1. AAC valve and assembly (including clean out and idle reset)
2. Connect Wires in steering column and check over. (hicas checkover)
3. Replace Fuel Filter and check out old one.
4. Check over Coil Packs and also cover in industrial silicone
5. Check and possibly replace coolant temp sensor.
6. Check AFM and Oxy Sensor for correct readings.
7. Check Injectors and clean if needed.
8. Check all intercooler piping for possible air leak... as i think thats where the backfire problem is occuring !!!!
#My car specs#
1989 R32 GTST
Rb20det
Standard Turbo
Standard boost (spikes to 11psi)
Standard plumb back bov (bloody noisy? possibly leaking somewhere?)
Standard Dump and Front pipes
3" Hi flow cat
3" Bee R cat back exhaust
New NGK Iridiums (standard gap)
CHEERS BOOSTA (Pete)
I put money on it that it is your ECU.
There is a series of actions you can perform to reset your ECU to factory settings. Do a search you should be able to find it.
If not let me know as I can find out.
Grippy.
if u wanna reset it, just unhook your battery and pump the brake pedal a few times.
i suggest taking the car to a workshop, they will find the problem alot quicker and easier than you will. charlies at wooloongabba know skylines very well, they deal with alot of them. im sure they will sort your problem out very quickly.
on the bov issue, u might find its stuck shut (if they can do that) the noise you are probably hearing is the flutter noise the air makes as it comes back out the compressor wheel of the turbo. try sourcing a new stock bov, it will most probably fix that.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
