R33 Gts-t Body Kit Parts For Sale + Muffler
Is the suspension at full droop? Try pushing up the lower arm with a jack. Careful not to lift the car off the chassis stands.
OK well I might narrow my search a bit then based on that. So your bearings from JustJap, did you use the existing hubs and press the old bearings out? Front ones I assume. I have my own bearing press, a small 12t one and I pressed my own new bearings and hubs for the rear, pretty easy but as they were new parts they weren't rusty like the ones I removed. I saw a Z1 370 rear upgrade kit, on my list for future upgrade.
Hey guys, im in the process of putting in my CV joints and there seems to be an issue where while I’m tightening the CV - HUB nut, it is pulling the stub axle on the diff out. I can see on the passenger side it is slightly out which I thought is normal. However on the drivers side it’s pulled out a lot further than the passenger side. I have the longer CV on the drivers side and shorter one on the passenger side. Does anyone have any suggestions for what I can do? cheers
There's the Apexi DIN3 meter however it's long been discontinued: https://www.apexi.co.jp/products/discontinued-products/din3-meter/ This guy installed one in a R34 Skyline 1DIN pocket using brackets which could go in the space for the radio? I don't own an R34 so can't confirm. https://minkara.carview.co.jp/userid/2839151/car/2447015/5771545/note.aspx If you could find one for sale it might do the job?
